Sphinx 55
Discussion in 'CNC Mills/Routers' started by Kyo, Feb 10, 2021.
  1. Kyo
    Kyo Veteran
    Kyo published a new build:
  2. Mark Carew
    Sweeet! wow @Kyo you have really taken this build to the next level. Nice job all the way from the use of the ferrules as well as overall wire management (10) to all the amazing 3d printed additions set off by great pics to showcase the work. Thank you for sharing the updated Sphinx build
  3. Kyo
    Kyo Veteran
  4. Woodsmith
    Woodsmith New
    Really nice to see someone showing how attention to detail and good practice makes for a polished machine. Thanks for sharing.
    Kyo likes this.
  5. Javit0
    Javit0 New
    Hola Kyo and community!
    Thank you for this awesome build. I've been learning a lot about CNC and Openbuilds with the Cbeam Plate-Maker in the last 18 months and I feel that this would be the next step in terms of rigidity in a small form factor and fixed bed. It looks astonishing.
    I'm trying to find out the shortest route with the parts I have and in the end I decided to jump into fusion360 to do the puzzle with what I have and the ones I need to buy. I just have a couple of questions that I was not able to find the answer in all the Kyo remixes. Maybe somebody could give me a hand:
    - Is there any consideration in having the Y motors in front of the machine instead of in the back? That way I can "close" the machine with a sheet of something in the back and control a little the mess the machine does with aluminum shavings/wood plastic... I'm actually not worried with the front wasted space because I usually use that to leave tools and whatnot.
    - Is is possible to have the z gantry in a platemaker XL style? With 6 wheels outside and the cbeam moving with the tool instead of 4 miniwheels inside the C track. I'm guessing that it was a tradeoff between cuantity of parts and rigidity, but I am not sure. I am not a machine designer, just a cheap remixer.
    Thank you again and to all the community. I've been learning a lot the last 8 months!!
  6. Hykr3n
    Hykr3n New
    Are custom stl file available?
    xlr mount is awesome!
    Kyo likes this.
  7. Giarc
    You can download the files and customize them. The original plates are here in the files section. C-beam Sphinx
    Kyo and Hykr3n like this.
  8. Hykr3n
    Hykr3n New
    Thanks. Im looking for the 3d printed part for the xyz probe
    Kyo likes this.
  9. Giarc
    If you are talking about this,
    I checked his Thingiverse account and was unable to find it there. It is strange it was not added in the file sections here. Kyo is a really thorough maker and has put files up of just about everything. Hopefully, he comes back soon.
    That being said, it looks like a fairly straight forward design, so it could be replicated easily enough.
    Kyo and David the swarfer like this.
  10. Hykr3n
    Hykr3n New
    it is exactly what i was looking for.
    Clever idea!
    Id like to add it my build
    thanks for your research!
    Kyo and Giarc like this.
  11. Kyo
    Kyo Veteran
    Thanks :thumbsup:. I am absent but not gone. The last few years I have been caregiver, driver and company for my aging family members. More recently dealing with funerals , estates ect. I hope to be more active again when things settle down and time is more my own.
    @Hykr3n
    I apologize for the slow response. After checking my Fusion 360 projects folder, I do still have that file. Please find attached the STL.
    Giarc, Hykr3n and David the swarfer like this.
  12. Kyo
    Kyo Veteran
    Here are the STL files for the toggle switch mount, rear bulkhead and belt cover I used on this build as well.
  13. Hykr3n
    Hykr3n New
    Thanks.
    Now i will finish my hgr15 sphinx build.
  14. ryder_koncepts
    May I ask where you got the plates for the HGR15. That is what I am looking for.
  15. Hykr3n
    Hykr3n New
    Hi. I was also looking for hgr plate so i designed them in sketchup.
    Haven’t tested them in alu yet,
    Let me know if you want file.
    Merry Christmas to all op builder!
  16. David the swarfer
    remember when generating gcode from sketchup for cutting aluminum to make sure ramping is on at a conservative angle AND make sure no short ramp segment got converted into a plunge, there will be a comment in the Gcode about it, so just read the Gcode. to force the ramp on a longer segment just put a 1% deep hole near where you want the cut to start then group the hole and the shape. groups will cut together, and groups will cut first, so the hole will get dotted then the ramp will start at the nearest point to the hole.
    Hykr3n likes this.
  17. ryder_koncepts
    That's awesome. I would love the files. Are you using lead screws or ball screw on this? I am assuming the standard 8mm lead screw. I was just asking because I bought SFU1605s and wanted to us them.
  18. Hykr3n
    Hykr3n New
    Yeah i use tr8*8
    I will try to find some ball screw one day.
    im still learning a lot on this machine.
    i will hit you in dm once home
    ryder_koncepts likes this.
  19. ryder_koncepts
    Awesome, Thank you. I have thought about going with a rack and pinion setup over the lead or ball screws. Still doing the research on that.
    Hykr3n likes this.
