Interface RJ connector wiring
Discussion in 'CNC Mills/Routers' started by Andyman257, Jan 7, 2024.
  1. Andyman257
    I am converting the interface 4 pin connector used on my old Blackbox 4x to my new Blackbox x32. i can't find any reference to the wiring of the connector at the RJ end. I don't want to make a guess and blow everything up. I am using a RJ11 screw terminal connector. Is there a repository of wiring diagrams?
    Contact the store, they have hybrid cables available. Pinout is printed near the connectors on the side of the devices
  3. Andyman257
    Thanks for your reply Peter. The RJ connector is the only one that doesn’t appear to have any label for pinouts. Is it possible that the circuit board has the information silk screened on it?
    #4 Peter Van Der Walt, Jan 7, 2024
  5. Andyman257
    Outstanding! Result! Thank you very much. I can’t believe I missed that in the documentation.
