BlackBox Contents
Discussion in 'CNC Mills/Routers' started by KCollins, Jun 26, 2023.
  1. KCollins
    KCollins Well-Known
    Is there a link... (other than the BlackBox Document) that better explains the contents of the BB? Because they are not covered in the BB document. I have an SD Card? What's that for? There is nothing on it and some little plastic block that looks like maybe a jumper maybe? Any help or documentation or link would be greatly appreciated. See attached image.
    Optional, if you wanted to try the WebUI instead of our recommended CONTROL software. See GitHub - grblHAL/Plugin_WebUI: ESP3D-WEBUI backend for networking capable drivers/boards with SD card support
    To try out the WebUI use CONTROL to put your BlackBox onto your Wifi network: docs:blackbox-x32:wifi_setup [OpenBuilds Documentation]
    Optional extra for customers who have an older Interface but orders the new BlackBox as an upgrade: Most likely not applicable to you, but if you do have an older Interface see section 5.6 of the Interface Docs
  3. KCollins
    KCollins Well-Known
    Awesome thanks Peter. Next I have a new question. In my new interface box was a usb thing. It doesn't look like a memory stick it looks like a cordless usb plug for a mouse. What is that?
    Read the Documentation - docs.openbuilds.com/interface explains that (it's a Flash drive but dont skip the Prepare USB Drive step of the docs)
    Also see docs.openbuilds.com > Software section
  5. Greg Casey
    hey Peter,, just getting started with X32, PSU and Openbuild Control --- it sees it - Loaded -- it sees it on the COM port, No Problem --- But in the bag is a 4-pin jumper with the SD card, what is that used for ????
    Greg Casey - [email protected]
    Extras. If you worked through the docs and nothing needed to be done with the jumper, put in a drawer. SD card is for if you someday want to play with WebUi, but also not needed, just a freebie
