Newby help with spindle on Shapeoko and OpenBuilds Control
Discussion in 'General Talk' started by David Haas Howard, Jan 16, 2024.
  1. David Haas Howard
    Greetings from Denver. I am new to OpenBuilds control. I have a Shapeoko Pro and I am interested in using open builds control. I am used to carbide motion starting and stopping the spindle automatically. How can I program Control to so the same thing? I only see an option to manually start it. When I do that it starts up but then the spindle stops within seconds of the machine moving.
    Also are there other settings that I should be using on the custom machine setup in Control?
    Thanks in advance for your help!
    Your GCODE contains the commands. Control just sends it along
  3. David Haas Howard
    I think I figured part of it out. I had it in laser mode. The next problem is how can I set a delay for the spindle to startup before it starts to cut?
    Same, the Gcode should contain the G4 (Dwell) commands to wait
    Typically something like
    M3 S1000 ; Turn spindle on
    G4 P8 ; 8 second wait for spindle
    G1.... ; moves continue after wait
  5. David Haas Howard
    Thanks for the quick reply. I use Vcarve pro for toolpaths. I looked at the shapeoko post processor and don’t see a G4 command. Can I just add it? Anyone done this before? Am I looking in the right place?
  7. David Haas Howard
