GRBL_SPD for Makita Routers
Discussion in 'CNC Mills/Routers' started by dJOS_500, May 31, 2023.
  1. dJOS_500
    dJOS_500 Journeyman
    looks like there’s another method, I haven’t tried it yet myself:
    FluidNC support · Issue #283 · OpenBuilds/OpenBuilds-CONTROL
    Code:
    change the startup message.
    Changing the startup string to Grbl \V [\H]
    Instead of Grbl_esp32 try grblhal :)
    dJOS_500 likes this.
  3. dJOS_500
    dJOS_500 Journeyman
    I mean the actual firmware itself
    Its fantastic
  5. dJOS_500
    dJOS_500 Journeyman
    Tbh, I couldn’t find any guides on configuring and compiling any normal versions of GRBL so I went with FluidNC.
    @Peter Van Der Walt do you know of a good guide for grblHAL? I'm curious to test it out but I can't really find any simple guides for idiots like me. There seems to be eleventy million options, but no concise guide for noobs.
    The web builder looks good, but doesn't let me specify a PWM spindle, or much else.
    #35 dJOS_500, Dec 3, 2023
  6. dJOS_500
    dJOS_500 Journeyman
    @Peter Van Der Walt I finally got my head around grblHAL - although I did end up needing "Config App" from ioSender to configure it as OB Control isn't fully aware of it it and thinks it's regular grbl.
    GRBL_SPD works very well in grblHAL with the following config:
    Code:
    $30=30000.000  ;  Maximum spindle speed, RPM
    $31=10000.000  ;  Minimum spindle speed, RPM
    $32=0  ;  Laser-mode enable, boolean
    $33=1000.0  ;  Spindle PWM frequency
    $34=0.0  ;  Spindle off Value
    $35=2.0  ;  Spindle min value
    $36=100.0  ;  Spindle max value
    Only if you compiled with compatibility mode. Grblhal support has been in CONTROL for over a year
  8. dJOS_500
    dJOS_500 Journeyman
    Ah right, I’ll double check as I can’t recall eat setting I used.
  9. dJOS_500
    dJOS_500 Journeyman
    i don’t think I did compile it with any compatibility settings on. Maybe I just found the OB settings hard to understand compared to Config App.
  10. David the swarfer
    um, nothing hard about this GRBL settings tab in OB CONTROL (-:
  11. dJOS_500
    dJOS_500 Journeyman
    Hmm, maybe it’s dark mode making it hard for me. The rest of the UI is great, but I found the settings page less clear. Settings are too spread out and not grouped logically.
    This is config app - it’s logically laid out and has generally great explanations of the settings. It’s not pretty, but it’s actually easier to use.
  12. dJOS_500
    dJOS_500 Journeyman
    GRBL_SPD v4 is about to be released and I was lucky enough to get one for testing. :cool:
    Introducing GRBL_SPD v4
  13. Steve Mecham
    Does anyone know if this will work with a duet 2 wifi? I'm guessing it would and I would just need to figure out the config in reprap but not sure.
  14. dJOS_500
    dJOS_500 Journeyman
    There's no reason it won't, assuming the Duet has a 5v PWM pin it can control as the "spindle" and set 0% = Off, 1% - 100% for 10k-30k RPM.
  15. Steve Mecham
    That's what I thought but I'm definitely not an expert. Thanks
    I think Duet's 3.3v so maybe add a level shifter to protect the Duet's GPIO
  17. Alex Chambers
    Duet is very flexible on its outputs
    Full info here;
    Duet 2 WiFi and Ethernet Hardware Overview
