DIY GoPro Camera Slider
Discussion in 'Other Builds' started by tonkajeep34, Nov 18, 2013.
  1. tonkajeep34
    tonkajeep34 published a new build:
  2. Mark Carew
    Man the shots your getting with this are great! The feet you mated to the rail are really cool I could picture them being able to wrap around anything like a tree for instance to get some amazing shots out in the woods.
    Very cool build thanks for sharing.
  3. tonkajeep34
    Yes exactly! Thanks for the compliments.
    Mike
  4. Mark Carew
    Welcome, thank you for sharing!
  5. Tom Gillam
    This is terrific. Just what I was looking for. I will search amazon for a slower motor per your suggestion. I am new to open builds and will hope to see your videos, which unfortunately were reported as "this video does not exist" I would love to see them. If you could share them, I am at [email protected] Thanks for sharing and thanks open builds.
    PS: I am up in the Sonoran Desert near the Superstition Mountains in Mesa AZ. I fondly recall at trip I made to Big Bend many years ago. Thanks for the memories.
  6. tonkajeep34
    Hi Tom, Yes i switched Gmail accounts a couple months ago... at the time seemed like a good idea. Oh well. I'll post them up again. It does work well. I ended up getting a couple of nuts that fit in the track that are 1/4" 20 thread so the tripods attach more securely directly to the rail which works well.
  7. Rick 2.0
    Where did you find the 1/4-20 nuts that fit the track?
  8. tonkajeep34
    Actually they didn't, I found some on Amazon that were close and ground them down enough to fit.
  9. tonkajeep34
    Not sure why the videos removed from the build when i tried to update it, but here they are
    Motor test:
    First Test outside:
    Second test outside:
  10. tonkajeep34
