V-Slot vs. T-Slot for Laser Cutter
Discussion in 'General Talk' started by alixohrt, Jan 23, 2024.
  1. alixohrt
    alixohrt New
    In researching, I understand that v-slot has a chamfered edge so it better allows for a wheel or guide to track in it for motion components. However, I'm looking to build a laser cutter - and the options to use all v-slot for the frame and gantry seems to be more cost effective than sourcing traditional t-slot from grainger, misumi, or another distributor.
    Are there any drawbacks to using the v-slot for all the structural framing components? Will standard t-nuts and connectors all still work as expected? Would love to just buy all v-slot from the store, especially if that saves money over other major distributors that charge and arm and leg for shipping.
    Thanks for the help!
    No drawbacks. V-slot is backwards compatible with T-Slot and most 20-series T-Slot accesories works just fine with V-Slot too.
    Check the BUILDS tab above - you'll see frames made of V-Slot on almost all the builds - been known to be cheaper for a while (;
  3. Alex Chambers
    Absolutely no drawbacks - many thousands of machines (including cnc routers which experience higher forces than a laser would) built entirely with V-slot.
  4. alixohrt
    alixohrt New
    Thank you both for the quick replies!
