Getting Probe error and alarm
Discussion in 'General Talk' started by Jayhawk714, Jan 25, 2024.
  1. Jayhawk714
    I am getting this error message when trying to start a job. Not sure what it means or how to fix it.
    Thanks in advance,
    Duane
    Probing with a V-Bit is incorrect, you can't position it correctly because of the taper - thats why it touches the side inside of centered inside the hole as it should be. Use a normal endmill or dowel pin to probe.
    The alarm says its touching the plate (which it is, because you are trying to probe with a non-cylinderical object)
  3. Jayhawk714
    Thank you again!! You are great andyou always teach me something and answer my questions fast.
