Square off bottom of text
Discussion in 'CAD' started by rbrown55, Feb 10, 2024.
  1. rbrown55
    rbrown55 New
    Can someone please guide me to the best way to square off the bottom of text to cut out a standing letter using Vcarve Pro?
  2. Giarc
    If you are trying to make it so the base of the letters meet the wood at a 90 degree angle, I would thing that a pass around the vectors that create the letters with a regular endmill that is small enough to get into the smallest corner of the letter would work.
    I also found this video, not sure if it is what you are looking for.
  3. rbrown55
    rbrown55 New
    No I simply want to square off the bottom of a letter like C or S so it has a flat base to stand up on. I will be cutting out a 30" tall letter. Just need to trim a small portion off the bottom to make it flat so it will stand up
    Tip : post some example pictures / napkin sketches of what you want to do. Would clarify and avoid confusion if included from the beginning
  5. jeffmorris
    jeffmorris Journeyman
    After creating text, draw a rectangle at the bottom of the text so that the text can stand up. Use scissors tool to cut out unnecessary lines and arcs or use combine tool to combine text and rectangle into one object.
  6. rbrown55
    rbrown55 New
    here is a pic
  7. Giarc
    Jeff's Idea above will work.
    Draw a box
    Convert text to curves:
    Select both. They will now both be dashed lines. Before, the text was solid.
    Now you can trim with the scissors trim tool. My cuts were exaggerated.
  8. rbrown55
    rbrown55 New
    Well this is where I just shale my head and realize I just have too much going on...LOL. I was actually trying to do the very thing Jeff mentioned before he even mentioned it and now that you have provided the screen shots I am able to see the step I missed and issue I had. Thank you all again.
    I need a vacation big time :)
