Z Motor doesn't move during homing - BBX32
Discussion in 'Controller Boards' started by vishesh, Feb 17, 2024.
  1. vishesh
    vishesh New
    I have a very strange issue with my BBX32. When I home all - X & Y motors homes correctly but Z motor doesn't move at all. But after homing cycle is complete I can move the Z motor through openbuilds control. Z Motor also works perfectly when I run any g-code through OC.
    Z motor also gets locked as soon as I connect my BBX32 with my pc. But it just doesn't move during homing.
    I have checked the Z limit switch as well. When I put a metal piece in front of z limit switch it shows triggered in OC.
    I am not able to understand what can be the issue.
    Check your Grbl Settings : $44=4, $45=3 should do. If not post a Grbl Settings backup for review
  3. David the swarfer
    maybe you flashed the ACRO XY only firmware?
    X32 does not need 2 axes firmware. Homing sequences can be set in Grbl Settings now ($44,45 etc) as masks
    edit: assume you mean 'does not need' (-:
    #4 Peter Van Der Walt, Feb 17, 2024
