Four X32 Blackboxes being used for 4 arms...
Discussion in 'Other Builds' started by Kasti, Feb 29, 2024.
  1. Kasti
    Kasti New
    Hi all,
    I'm using four X32 Black-boxes to control four arms, respectively one box per arm. The X's, Y1/Y2s & Z's are handled by arms 1 & 3, while arms 2 & 4 handle their respective X / Z only w/their limit switches - Y1/Y2 on these boxes are not plugged in. Arms 1 & 2 are on the same Y track, while 3 & 4 are similar When creating the firmware changes I wanted using OpenBuildsControl I noticed that when homing arms 2 & 4 using 'Home All' does not fully home them. What happens is: The Z-axis acts normally when resetting itself, but the X-axis will run into the limit switch and pull-off - it just sits there. I'd like it to ideally: Home Z-axis, then X-axis & sit at its new home coordinate. Again, the Y-axis' is handled by its partner Black Box.
    I've read that I can modify my config.h for grblHAL to tell my black-boxes to not home for Y, considering this reference post... - Would this be an optimal solution? I also have considering splitting my wires for my X-motor to attempt to trick the box into thinking a Y-axis is plugged in, but I assume this will spawn further issues....
    Settings for box 2 as reference:
    $0=10.0 ; Step pulse time, microseconds
    $3=4 ; Step direction invert, mask
    $4=0 ; Invert step enable pin, boolean
    $5=7 ; Invert limit pins, boolean/mask
    $6=1 ; Invert probe pin, boolean
    $8=0 ; Ganged axes direction invert as bitfield
    $9=1 ; PWM Spindle as bitfield where setting bit 0 enables the rest
    $10=511 ; Status report options, mask
    $11=0.010 ; Junction deviation, millimeters
    $14=0 ; Limit pins invert, mask
    $15=0 ; Coolant pins invert, mask
    $16=0 ; Spindle pins invert, mask
    $17=0 ; Control pins pullup disable, mask
    $18=0 ; Limit pins pullup disable, mask
    $19=0 ; Probe pin pullup disable, boolean
    $21=1 ; Hard limits enable, boolean
    $22=1 ; Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
    $23=3 ; Homing direction invert, mask
    $24=100.0 ; Homing locate feed rate, mm/min
    $25=1000.0 ; Homing search seek rate, mm/min
    $28=0.100 ; G73 retract distance, in mm
    $29=5.0 ; Step pulse delay (ms)
    $30=1000.000 ; Maximum spindle speed, RPM
    $31=0.000 ; Minimum spindle speed, RPM
    $33=5000.0 ; Spindle PWM frequency
    $34=0.0 ; Spindle off Value
    $35=0.0 ; Spindle min value
    $36=100.0 ; Spindle max value
    $37=0 ; Stepper deenergize mask
    $39=1 ; Enable printable realtime command characters, boolean
    $40=0 ; Apply soft limits for jog commands, boolean
    $43=1 ; Homing passes
    $44=4 ; Homing cycle 1
    $45=3 ; Homing cycle 2
    $46=0 ; Homing cycle 3
    $62=0 ; Sleep Enable
    $63=2 ; Feed Hold Actions
    $64=0 ; Force Init Alarm
    $65=0 ; Require homing sequence to be executed at startup
    $70=7 ; Network Services
    $73=1 ; Wifi Mode
    $74= ; Wifi network SSID
    $75= ; Wifi network PSK
    $100=199.100 ; X-axis steps per millimeter
    $101=199.100 ; Y-axis steps per millimeter
    $102=199.100 ; Z-axis steps per millimeter
    $111=2500.000 ; Y-axis maximum rate, mm/min
    $112=2500.000 ; Z-axis maximum rate, mm/min
    $120=150.000 ; X-axis acceleration, mm/sec^2
    $121=150.000 ; Y-axis acceleration, mm/sec^2
    $122=150.000 ; Z-axis acceleration, mm/sec^2
    $130=810.000 ; X-axis maximum travel, millimeters
    $131=730.000 ; Y-axis maximum travel, millimeters
    $132=90.000 ; Z-axis maximum travel, millimeters
    $300=Grbl ; Hostname
    $302=192.168.5.1 ; IP Address
    $303=192.168.5.1 ; Gateway
    $304=255.255.255.0 ; Netmask
    $305=23 ; Telnet Port
    $306=80 ; HTTP Port
    $307=81 ; Websocket Port
    $341=0 ; Tool Change Mode
    $342=30.0 ; Tool Change probing distance
    $343=25.0 ; Tool Change Locate Feed rate
    $344=200.0 ; Tool Change Search Seek rate
    $345=200.0 ; Tool Change Probe Pull Off rate
    $346=1 ; Restore position after M6 as boolean
    $370=0 ; Invert I/O Port Inputs (mask)
    $384=0 ; Disable G92 Persistence
    $396=30 ; WebUI timeout in minutes
    $397=0 ; WebUI auto report interval in milliseconds
    $398=35 ; Planner buffer blocks
    $481=0 ; Autoreport interval in ms
    $I=unconfigured
    Homes Z, then homes XY?
    1=X
    2=Y
    4=X
    $44=4 thus = Z only
    $45=3 - to get 3 you need 1+2 = X and Y.
    Would be
    $44=4
    $45=1
    Kasti likes this.
  3. Kasti
    Kasti New
    Thank you! Feel a little dumb after seeing how simple this was :)
