Sherline CNC lathe conversion
Discussion in 'CNC Lathes' started by Tourniquet63, Mar 7, 2024.
  1. Tourniquet63
    I have gotten ahold of a sherline CNC lathe. It is complete with steppers but does not have any controller board / drivers.
    Can I use the blackbox to retrofit this?
    Possibly, depends on the electrical specs of the motors. Try look for a datasheet of yours
  3. Tourniquet63
    It is a small lathe. The two steppers are listed at 2.1 amps. The sindle motor is listed at 90V DC but I have the DC electronics speed control board. I will have to figure out how the Blackbox can control this board. It looks as though it is normally controlled manually through a potentiometer. So maybe a digipotentiometer (Digital Potentiometer - 10K - COM-10613 - SparkFun Electronics) could be used and controlled by the blackbox?
    #3 Tourniquet63, Mar 8, 2024
    Are they Bipolar? Voltage? (3-6V for BlackBox ideally, higher will limit acceleration), Inductance? (1-2mH ideally, higher will be slower on top speed) - that's why the datasheet's important - you need the full picture, all values, not just one parameter
    We provide industry standard 0-10v and PWM outputs. Does this board have a manual or other documentation to see what inputs its accepts?
  5. Tourniquet63
    Yes the steppers are 3.2V. I believe the inductance is 3.6 but I will have to get a mutimeter to measure it for sure.
    I contacted Sherline for any documentation available on the board. The most common use of the board though is to just be controlled with a physical potentiometer.
    Should be usable then.
    Spindle we'll confirm when we get more details then.
    In the meantime, checkout docs.openbuilds.com > Software and also the BlackBox X32 sections
  7. Tourniquet63
    Thanks Peter. An immense help as always!
  8. Tourniquet63
    Still working on this build.
    I wanted to make sure these limit switches would work. They are the stock switches on the sherline cnc lathe. Closest part I could find.
    Looking at the documentation they are most like the lever micro limit switches - I just wanted to make to make sure that they should read as open when connected, and then closed when pressed.
    Or other way round. Just match up $5 Invert settings.
    Without filters Normally Closed might be a little better
    Tourniquet63 likes this.
