Plasma cutting
Discussion in 'OpenBuilds Forum Help' started by jurac, Mar 13, 2024.
  1. jurac
    jurac New
    Can somebody know why cut in X axis is smooth but on Y xis is very rough
  2. jurac
    jurac New
    Any chance the compressor tank had trained during the nicer bit, then kicked in the compressor to run - while it was making the choppier bit? Looks almost like the air pressure was fluctuating, which could be explained if its a piston type compressor and it was running at the time?
  4. jurac
    jurac New
    Compressor was not running. It is 10bar so plenty of air :)
    What's the machine itself? What kind of drive system? More info you give the better the guesses we can try (;
  6. jurac
    jurac New
    Drive siystem is belt gt2. It has floating x axis. Basically it is diy unit :D
  7. jurac
    jurac New
    And for now i only have 1.1mm nozzle. And material is 2mm thick. And is running on adurino uno :)
