iot relay will not shut off
Discussion in 'General Talk' started by bubbatay, Mar 20, 2024.
  1. bubbatay
    bubbatay New
    I am using a iot relay with my xcarve 1000 x 1000. When I start a project the router starts fine but when the carve is complete the router does not shut off. is there a grbl setting i should be looking
    Does your gcode contain a spindle off command at the end?
    Is the IoT wired to Tool Enable or Tool PWM?
    Is it a BlackBox or some other controller?
