Post Processor Fusion 360
Discussion in 'Control Software' started by Grant Oglesby, Mar 29, 2024.
  1. Grant Oglesby
    I am receiving errors when trying to post in Fusion 360. I installed the latest update to fusion 360 and also did the latest update to the post processor. Any help would be greatly appreciated, I see on the post processor site that they are working on a new version to fix this issue, I just fail to see where to grab it from.
    Information: Configuration: OpenBuilds CNC : GRBL/BlackBox
    Information: Vendor: OpenBuilds
    Information: Posting intermediate data to 'D:\CNC\tghldr.gcode'
    Information: Total number of warnings: 2
    Error: Failed to post process. See below for details.
    Code page changed to '1252 (ANSI - Latin I)'
    Start time: Friday, March 29, 2024 5:12:41 PM
    Code page changed to '20127 (US-ASCII)'
    Warning: (OpenbuildsFusion360PostGrbl.cps:314) Setting read-only property "power" on object of type "PostProcessor". This will have no effect.
    Post processor engine: 5.131.1
    Configuration path: C:/Users/Go_Lu/AppData/Local/Autodesk/Autodesk Fusion 360/K7K3P7UWPP53/W.login/M/D20200926336931981/CAMPosts/OpenbuildsFusion360PostGrbl.cps
    Security level: 1000
    Include paths: C:/Users/Go_Lu/AppData/Local/Autodesk/Autodesk Fusion 360/K7K3P7UWPP53/W.login/M/D20200926336931981/CAMPosts
    Configuration modification date: Friday, March 29, 2024 3:16:04 PM
    Output path: D:\CNC\tghldr.gcode
    Checksum of intermediate NC data: 6af47cccae6ee6744244891825889730
    Checksum of configuration: 90a3b9d57936aeb6022c556bcdf522af
    Vendor url: Build List | OpenBuilds
    Legal: Copyright Openbuilds 2023
    Generated by: Fusion CAM 2.0.18719
    Warning: Invalid Work Coordinate System. Select WCS 1..6 in SETUP:postProcess tab. Selecting default WCS1/G54
    Error: Failed to invoke method of class 'PostProcessor'.
    Error at line: 958 (OpenbuildsFusion360PostGrbl.cps)
    Error in operation: '2D Pocket1'
    Failed while processing onSection() for record 466.
    Error: Failed to invoke function 'onSection'.
    Error: Failed to invoke 'onSection' in the post configuration.
    Error: Failed to execute configuration.
    Stop time: Friday, March 29, 2024 5:12:41 PM
    Post processing failed.
  3. Grant Oglesby
    Updated, still getting errors.
    Error at line: 1136 (OpenbuildsFusion360PostGrbl 3.cps)
    Information: Total number of warnings: 1
    Start time: Friday, March 29, 2024 6:08:53 PM
    Configuration path: C:/Users/Go_Lu/AppData/Local/Autodesk/Autodesk Fusion 360/K7K3P7UWPP53/W.login/M/D20200926336931981/CAMPosts/OpenbuildsFusion360PostGrbl 3.cps
    Configuration modification date: Friday, March 29, 2024 5:59:12 PM
    Checksum of intermediate NC data: b1e76ac7bb728b22c959be50316379b2
    Checksum of configuration: ee790eb427a50f639a79d354b94b7b3c
    Legal: Copyright Openbuilds 2024
    Stop time: Friday, March 29, 2024 6:08:53 PM
  4. David the swarfer
    please send me your Fsuion360 drawing file so I can debug this.
    never mind, looks like the recent changes messed with the 'alert' method, I will fix that but meantime....
    instant fix is for you to actually select a WCS in the setup|postprocess tab as the warning indicates.
    right click the setup
    select 'edit'
    select 'post process' tab, on the right
    set 'WCS Offset' to 1
    right click the edit box
    select 'save as user default'
    now this setup is set to use G54 AND future setups should default to use it as well
    #4 David the swarfer, Mar 30, 2024
  5. Grant Oglesby
    Sir,
    this worked, Thank you very much.
  6. Thomas Lamourine
    OK, was getting that error and the fix, for that one, but also getting this error.
    Guess it doesn't mean anything really but it's annoying to always have the error and checking.. is there something I'm doing wrong or something I can fix myself? I can't find any explanation for the error or what it actually means (other than the obvious something to do with Power LOL)
    Thomas Lamourine likes this.
  8. Thomas Lamourine
  9. David the swarfer
    you need to upgrade your postprocessor, the recent Fusion360 upgrade broke the 'power' variable usage.
  10. Thomas Lamourine
    yea... is there a simple "copy - paste" method of that text file? I went to download and do the whole install but that file says its like from 2023, the linked file above is all text off GitHub... I did a search but just got so many off topic links I just go more confused... demo/instructions or something easy? LOL.
  12. Thomas Lamourine
    oh crap. I forgot about that page... been so long since I did any of this!! I just used it without thinking for so long! thanks guys!!!
  13. Thomas Lamourine
