gcode running a circle doesnt work using G02 I, help
Discussion in 'General Talk' started by Chesney, Apr 1, 2024.
  1. Chesney
    Chesney New
    Hi, I have written a code on Nc Viewer and it works perfectly, using same code on OB control doesn't cut circles.
    Why is this does OB not recognize the I for full circle? I am stumped,
  2. Misterg
    Misterg Veteran
    Can you attach your code so that we can see it?
    Do you get any error messages? If so, what [exactly] are they?
    Are you using relative or absolute offsets for the G2 command? There are different requirements for the arguments following it - see section 5.1 in the linuxCNC documentation:
    G-Codes
  3. Chesney
    Chesney New
    the line for the code is G02 I7.5 everything else worked fine just this line doesnt want to work. im new to the codes and files so yeah im learning.
  5. David the swarfer
    GRBL only uses relative I J K offsets, LinuxCNC can use absolute or relative.
    also, although GRBL can do full circles, it does not always work, better do restrict arcs to 180 degrees
    Misterg likes this.
  6. David the swarfer
    GRBL wants X Y I J on every G2/G3 line.
    writing your own Gcode is an excellent vehicle for learning Gcode, but using a CAM for production code is much more efficient and less prone to crashing the machine horribly (-:
