Image jogs during etching
Discussion in 'OpenBuilds Forum Help' started by Ray Taggart, Apr 8, 2024.
  1. Ray Taggart
    I'm having an issue with Lightburn. I have opened a lightburn forum discussion with no progress, So, I'm hoping the Openbuilds Collective can help.
    I have an Openbuilds Lead 1010 w/blackbox x32 controller and the Jtech 44w Octo Pro laser attachment. I using a pretty fast Windows 10 laptop to run everything. Here’s my problem. I’ve burned a dozen or so small photos and this weekend I tried a 10x10. The image starts off great, then after about 1/2" into the photo the whole image takes a big jog. This issue keeps repeating at different intervals throughout the image. Here’s a photo
    Any Ideas?
    Thanks in advance....Ray
    Couple possibilities
    • grubscrew on shaft coupler slightly loose causing slip during direction changes
    • max rate set too high - causing stall when it gets up to speed Grbl v1.1 Configuration
  3. Ray Taggart
    Hello Peter, Thank you for your help! I double checked the set screw in the coupler and they are all tight.
    So I went into lightburn to change the speed settings. On my first post (above) the setting were 175 ipm at 40% power. So I changed the settings to 100 ipm at 20% power. The speed change was obvious. It made it through 2" with no problems, I thought great, the speed was the problem, BUT then at about 2.5" it took a 1/2" jog.
    your suggestion that the max rate is too high makes sense, Shouldn't changing the speed settings in lightburn change the Grbl configuration. Once again, I'm stumped.
    I am not sure if Lightburn can edit Grbl settings, why not use CONTROL, tune it correctly: Grbl v1.1 Configuration and Grbl v1.1 Configuration then handover back to Lightburn as a CAM?
    Grbl wiki describes the procedures
  5. Ray Taggart
    Thanks again! I'll try your suggestions, using CONTROL and then Lightburn and let you know.
    Cheers....
    ps. being new to all this, it really helps a LOT to have someone replying and trying to help me!
  6. Misterg
    Misterg Veteran
    No, it doesn't - it just changes how fast Lightburn asks the the GRBL controller to move.
    Given that you've had the same thing at two different speeds, it's *probably* the acceleration settings that are a little too aggressive. You can't (sensibly) set these from Lightburn - go into Control; the Grbl Settings tab and look at $120 and $121 settings.
    My suggestion would be to reduce them by ~50% and see if you still have an issue. If not, try increasing by 50% of the new value and testing again - repeat until you start getting problems and then reduce to about 80% of whatever value that is.
    Good luck :)
  7. Ray Taggart
    You, and Peter were right. It was the $120 and $121 settings. I reduced both by 50% and everything worked great. It took a long time, but it worked. Now I'm tweeking the setting to find the optimal settings.
    Thank you both so much! without your help, I never would have figured this out.
    Cheers.
    Misterg likes this.
