Y-Motors don't move the same distance
Discussion in 'CNC Mills/Routers' started by Keith Kimura, Apr 17, 2024.
  1. Keith Kimura
    I have a Workbee 1010 with Black Box 32. When moving the Y-Axis 10mm one motor moves 10mm while the other moves 11.2mm. What should I investigate to fix this?
    Most likely something mechanical. Loose setscrews on shaft coupler, loose stop collar, etc
    Perhaps one side binds a little, or stalls. OpenBuilds Motors (or high inductance 3rd party motors?)
    The two Y motors get the same amount of steps. Check your steps per mm, should be around 199-200 steps per mm (our 8mm Leadscrews)
  3. Keith Kimura
    Thank you Peter, I'll recheck all of the mechanical connections, although I've done this dozens of times already. The motors are Openbuilds high-torque. Unfortunately the lead screws are not Openbuilds. I purchased a Linear Rail kit from SPAM-3D and have had nothing but problems with this rebuild. My CNC has been out of operation for almost a year due to the lack of support from them when they shipped wrong or defective parts (from China). Lesson learned here - I'll have to live with it and keep working on it. If anyone is considering this mod I don't recommend SPAM-3D; very costly experience. Every encounter with Openbuilds for all the other parts and info has been top-notch - much appreciated.
    Could take them out, lay them side by side and see if the helixes line up - might be rolled out of spec (replacements needed)
