Stopping program run
Discussion in 'Control Software' started by Svechnikov Workshop, Apr 18, 2024.
  1. Svechnikov Workshop
    Continuing to set up the new CNC machine
    The program stops performing the task at random locations. No errors in the log. The spindle continues to run at the same time. The program cannot be paused, but can be interrupted by pressing Stop. The spindle stops. OpenBuilds Control does not hang. When I press Run, the program starts from the beginning. The coordinates are not lost
  3. Svechnikov Workshop
    Code:
    [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    This line appears after I press STOP
    Ok that's actually good then probably just EMI, not a short
    Svechnikov Workshop likes this.
  5. Svechnikov Workshop
    Just want to make sure I have to do more competent cable management
    I see a lot of low voltage cabling right past a noisy (electomagnetic radiation wise) VFD
    VFDs also need good shielded cable, proper earthing etc. They can cause more EMI issue than the other issues they "solve"
  7. Svechnikov Workshop
    I don't claim perfect cabling, but stopping are gone. I ran shielded power cables, installed an EMI filter, and separated the cabling. Thanks for your patience!
