Post Fail - Fusion 360 & Open Builds
Discussion in 'CNC Mills/Routers' started by Dave Dreher, Apr 22, 2024.
  1. Dave Dreher
    Hello, been using my black box trouble free for years. And I run it a lot right now, 20-30 hours a week.
    I use Fusion 360, I also have the Open Builds G-Code software loaded on the cloud in Fusion. I'm not a programmer! LOL. All of a sudden I'm geeting a failure to post on any file. Here is the code, or error.
    Any thoughts?
    Information: Configuration: Open Hardware CNC Router V11 using GRBL
    Information: Vendor: Openbuilds
    Information: Posting intermediate data to 'C:\Users\DaveDreher\Desktop\Post Fail.nc'
    Information: Total number of warnings: 1
    Error: Failed to post process. See below for details.
    Code page changed to '1252 (ANSI - Latin I)'
    Start time: Monday, April 22, 2024 4:16:05 PM
    Code page changed to '20127 (US-ASCII)'
    Post processor engine: 5.131.1
    Configuration path: C:/Users/DaveDreher/AppData/Local/Autodesk/Autodesk Fusion 360/FBQHPEY6PFXL/W.login/M/D20190902212171206/CAMPosts/OpenbuildsGRBL.cps
    Security level: 1000
    Include paths: C:/Users/DaveDreher/AppData/Local/Autodesk/Autodesk Fusion 360/FBQHPEY6PFXL/W.login/M/D20190902212171206/CAMPosts
    Configuration modification date: Sunday, April 10, 2022 10:20:37 PM
    Output path: C:\Users\DaveDreher\Desktop\Post Fail.nc
    Checksum of intermediate NC data: 520ad8b203f57af7f5f924f771dbcebc
    Checksum of configuration: 283440fe2e86f74a33be54d679e18709
    Vendor url: Build List | OpenBuilds
    Legal: Copyright (C) 2012-2019 by Autodesk, Inc.
    Generated by: Fusion CAM 2.0.18961
    Warning: Invalid Work Coordinate System. Select WCS 1..6 in CAM software. Selecting default WCS1/G54
    Error: Failed to invoke method of class 'PostProcessor'.
    Error at line: 464 (OpenbuildsGRBL.cps)
    Error in operation: 'Face1'
    Failed while processing onSection() for record 360.
    Error: Failed to invoke function 'onSection'.
    Error: Failed to invoke 'onSection' in the post configuration.
    Error: Failed to execute configuration.
    Stop time: Monday, April 22, 2024 4:16:05 PM
    Post processing failed.
  2. Alex Chambers
  3. Dave Dreher
    Alex, I was thinking this might have been the issue. FYI, last night I thought I uploaded the newest version.
    I just deleted the old one, then loaded the newest one. Same issue, failure to post. At this point I'll check back and see if other folks run into same issues and see if there is a fix. The two appear to not be compatible anymore, or there is some user error.
    You should be on V1.42 OpenBuilds-Fusion360-Postprocessor/OpenbuildsFusion360PostGrbl.cps at master · OpenBuilds/OpenBuilds-Fusion360-Postprocessor
    Also, set your WCS please:
  5. Dave Dreher
    Thanks Peter. I'll look back at it this evening.
  6. Curtis Soldano
    Hello.I started following this thread because I was having the same issues.
    Happy to say, even thought it took my a few times to get it right, the suggested fixes on this thread solved my problem too. Thank you to learned members of this group for carrying and caring for this seed of knowledge, I had fussed with this a few times and did some searches and wasnt finding anything relevant until this thread. Ive invested a lot of time learning fusion and I was starting to get worried that I was going to have to delve into other apps and lengthen my already long learning curve. Thanks to the community and the author/maintainers of that post code, I am both in your debt and terrified of my dependence on you. :)
    I just did one spot check but Im going to go back and re-post some of my other projects to make sure I got things done correctly. This has been stifling me for a few months so I am excited to make some chips.
    With Graitude!
  7. Alex Chambers
    You can thank @David the swarfer for all the work he (and others) have done to create and maintain that post processor, which is one of the most comprehensive I've seen.
  8. Dave Dreher
    Following the guidance from Alex and Peter, I'm back up and running! Thanks
