No a circle just ovals
Discussion in 'General Talk' started by jltcet, May 5, 2024.
  1. jltcet
    jltcet Well-Known
    Ok another NOBO question here when I design this in F360 it’s supposed to be a prefect circle in step it’s smaller then designed. Is this something to do with the Y axis leads I have calibrated the machine a few times I’m using it’s as follows
    (T8 1000mm Lead Screw Diameter 8mm Lead Screw Pitch 2mm,Lead 2mm) it has 1start not the normal 4starts I can’t find a 1 star lead in the settings just open builds leads screws. No custom settings any suggestions on my current lead screws with out having to purchase any parts right now
  2. sharmstr
    If you're using CONTROL, use the calibration wizards in the Tool and Wizards menu. Calibrate using the longest distance that you possibly can.
