Project Extra strong corner brace plates 2015-02-27
Strengthen your OX Y extrusion & improve your GT3 belt attachment
  1. sgspenceley
    sgspenceley Veteran
    sgspenceley submitted a new resource:
    Extra strong corner brace plates - Strengthen your OX Y extrusion & improve your GT3 belt attachment
  2. sgspenceley
    sgspenceley Veteran
    I suggest using, 1/8th mild steel or 1/4" aluminum.
    I used 1/8" mild steel which was laser cut.
    Depending upon the bumpers and proximity switches you may want to consider adjusting the size of the outer holes.
  3. sgspenceley
    sgspenceley Veteran
    A few example prices.
    1/8” mild steel $8.75 US Each
    1/8” Alum 6061 $13.50 US Each
    1/4” Alum 6061 $16.75 US Each
  4. sw3Dp
    sw3Dp New
    Steve,
    I've been looking at a lot of designs, the original OX etc, that all follow what you have done with a few of yours, namely you join the frame stacked on top instead of butting them in a low flush profile. What is the advantage of raising the x extrusions above the floor so to speak is it just for v track clearance of the gantry? In your linear design also the bed is under the x drive motor.
    jack
    #4 sw3Dp, May 21, 2015
