Power supply not working.
Discussion in 'General Electronics' started by Kasey F Kessler, Jul 8, 2021.
Thread Status:
Not open for further replies.
  1. Kasey F Kessler
    I recently put together the c beam model and the 24v power supply is not turning on. I've set it to 115v, and I can't see any issues with the wiring. The power button lights up, but nothing else comes on (fan, power light...etc). Any idea what might be wrong
    Check in with http://support.openbuilds.com/support/home > New Ticket for assistance :)
  3. Jonathan Millham
    Did you find out what was wrong by any chance? Having the same issue.
  4. Yvette Sargent-Quintana
    I just installed my open builds blackbox power supply and x32 controller and this is what is happening - no power
    All the LEDs are lit so its powered up.
  6. Yvette Sargent-Quintana
    So the fan on the controller and power supply don’t need to run?
    PSU fan is temperature controlled. Have read through the datasheet, Fan is on page 2, about halfway https://www.meanwell.com/Upload/PDF/LRS-350/LRS-350-SPEC.PDF
    Controller (assuming its a BlackBox) should have the fan on all the time. Post pictures of your wiring for review
  8. Yvette Sargent-Quintana
    Yes *** blackbox
    Your pictures shows X32s fan is spinning
  10. Yvette Sargent-Quintana
    Light is on, fan not spinning
    Thanks, the photos are vague, the Fan has blue LEDs as well, so hard to see with the angles provided.
    Further investigation into pictures: Power switch is in OFF position
    Note you also have this issue reported in duplicate via store support: Ticket 68021
    Lets avoid duplication and continue the discussion via the store support. Thanks
  12. Misterg
    Misterg Veteran
    Just a thought: Probably the camera angle but it looks like both wires are connected to V+
    (If not, it looks like they are connected the wrong way around!)
    No the V+ notation is to line up with PSU terminals, the board itself has a terminal on it .
    See docs:powercase-v1.9:start [OpenBuilds Documentation] and then wired as docs:blackbox-x32:connect-psu [OpenBuilds Documentation] off the pluggable terminals
    Has black / GND on the left so looks fine now (unless it was reversed earlier and corrected before picture was taken)
    Misterg likes this.
Thread Status:
