Black box 32x to relay
Discussion in 'Controller Boards' started by Adam Jelinek, Jun 16, 2024.
  1. Adam Jelinek
    What connection do I need for the iot relay. Tool, pwm, 0-10v??
  3. Adam Jelinek
  4. Adam Jelinek
    View attachment 61053 [/QUOTE]
    Quick question. Is the router supposed to keep running of you stop the job or abort it? It currently works correctly with tool on and tool off buttons. But if you have to stop the job or abort the router keeps running. Even doing a stop tool won't stop it. Is this normal?
  5. Adam Jelinek
    If I wanted to add a second IOT relay where would I connect it? The coolant spot is used up the spindle light.
    The question might be, what does the second relay need to do? If its for coolant or dust, the coolant output still makes most sense.Can run both LED and Relay off Coolant. Or move LED to PSU (always on)
  7. Adam Jelinek
    The second relay would be for a vac system
    Then Coolant makes the most sense to me.
