C-Beam XL Gantry Plate... ?
Discussion in 'Concepts and Ideas' started by dioramym, Jul 20, 2019.
  1. dioramym
    dioramym New
    Heloooo...
    Where i find part from title in PDF drawings... ?
    I found this, but i don't now is correct...
    Regards.
      .jpg
      File size:
      66.7 KB
      448
    #1 dioramym, Jul 20, 2019
  2. Rick 2.0
    That drawing is probably accurate but there are times that slight modifications are made to the designs by the home office to improve fit which are generally only forwarded to the manufacturer. It should be noted that the pdf drawings that are posted were done before this part came along. Is there a specific reason you're asking?
  3. dioramym
    dioramym New
    He is currently designing the machine and it is about redrawing it in cad developers where I can manipulate the project.
    Is there a chance to file this part in SW 2012 format ...?
    Or PDF ...?
  4. Rick 2.0
    If it's not in the resource section then it is probably not available. Only a very small percentage of the forum uses SW in their designs and any updates if available would be coming from that group. Hopefully someone will speak up and provide it but otherwise the only other option would be to pull the dimensions you seek off of the Sketchup files.
  5. dioramym
    dioramym New
    Thank you...
    I hope someone will help me in this matter ...
    Unfortunately, I do not know Sketchup, so it will be hard for me to embrace it.
  6. Bryan Cope
    Here is a DXF. one version is just the plate, the other is the original file from C-Beam Gantry Plate Xlarge
    Its missing a set of holes, but its a start
    Hope it helps
