OpenBuilds CONTROL Software
  1. Peter Van Der Walt
    2D not an option at this time. Best to use a machine that can handle the workload
    Might run better on Windows with the same hardware (Better GPU drivers, depending on what GPU it has, still today linux GPU drivers can sometimes be a source of frustration)
  2. kaoscreations
    UHOOO I LOVEEEE :) thanks, it's perfect!!!!!
  3. bpresten3
    bpresten3 New
    How do you add a e-stop button to the Grbl settings if you are using a Arduino uno board with openbuild firmware. Where do you terminate the button to
  4. Giarc
    Connecting Grbl
  5. bpresten3
    bpresten3 New
    so i would need to use the A0 pin and ground
    correct?
  6. Giarc
    If it is truly for an emergency, place the E-stop on the main power to your machine so if a true emergency happens, all power is cut. I have used this on both my CNC Lathe and my CNC Router. Amazon.com
    This is even easer and requires no cutting of power cords for wiring into plugs like the first one. https://www.rockler.com/safety-power-tool-switch.
    But to answer your question, A0 and Ground, but the two switches I show above are far easier and safer. If a body part is being mangled by the machine, Feed Hold/Abort won't stop it unless you get the router off.
    #2676 Giarc, Jun 10, 2024
  7. JustinTime
    I use both emergency switches. The one that only stops the program from running, the A0 to ground, and the one that cuts off the power to the whole system, the one that Craig linked to Amazon.
  8. bpresten3
    bpresten3 New
    Is the config that yall are using is the Openbuild JDs garage and is that IO point a standard for all configs
  9. Jon Hoogeveen
    Hi Peter,
    Looking for some help -
    No matter what we try, cannot get the laser to turn off between letters in Control or Lightburn.
    Almost seems like the PWM isn't turning off to 0 completely. Green traverse lines are always being etched, resulting in messy etching.
    Combo is Acro 510 and Opt PLH3D-XT with the CNC adapter. upload_2024-7-2_13-42-55.png
    Any ideas?
    Mark Carew and Jon Hoogeveen like this.
  11. Jon Hoogeveen
    Got it, had it wired to the tool enable - thanks much!
    Jon
  12. GS76
    GS76 Well-Known
    To whom it may concern:
    I am trying to set the soft-limits for a desktop CNC machine running the X32 BlackBox controller. I do not have any hard-limit switches enabled.
    When I “incrementally jog” the X-axis (no other axes are connected as yet) but it does not go into feed-hold or stop.
    I have attached a back-up of the settings from the controller.
    What am I doing wrong or is it not possible to do what I want to do?
    Thank you for the support.
    1) Did you home the machine prior to testing (Soft Limits applies in Machine coordinates, needs to be homed)
    2) Soft Limits Enabled in Grbl Settings?
    3) $40 set to 1?
    4) Max Travel distances correct?
    CONTROL will check if you have Soft Limits enabled, then see what the value of max travel is, and just never send jog moves that will exceed the remaining travel. It wont "go into feedhold" (thats for pausing a job) it will just push it as far as allowed in jogging. Pretty silently stopping you from exceeding the Max Travel distance away from Home.
  14. GS76
    GS76 Well-Known
    Thank you for the reply, Peter,
    For your first question, are you referring to the setting of the pre-defined position or the bottom screenshot referring to “G53” gotozero options?
    Can the options in the “gotozero” drop-down be changed? I am asking as my machine cannot travel those distances. It is made for a specific-function for material testing. I would not want to travel more than +/- 2 mm for each axis.
    Or do I run my own G53 sequence? The machine axes are in the correct position at this point.
    Thank you for the help.
    I am referring to Home. Between Check Size and Wizards and Tools up top.
  16. GS76
    GS76 Well-Known
    I am not quite following you, but I will test.
    Click Here
    To satisfy
    That's all
  18. GS76
    GS76 Well-Known
    Thank you, Peter,
    Tried it and had messages stating it could not find the hard limit switches, which I do not have.
  19. Peter Van Der Walt
    Did it move towards the switches (if not, $23 Homing dir in Grbl Settings - tell it where the switches are)
  20. GS76
    GS76 Well-Known
    Apologies, I stated at the beginning of our thread but did not mention it again above. I do not have hard-limit switches.
    What is the best procedure to follow then? Just keep using G28 and G30?
  21. Peter Van Der Walt
    Oh wait theres the problem! Get some! :) You can't use soft limits without homing. You need to Home (soft limits, machine coordinates, and a lot of other offsets depend on it)
  22. GS76
    GS76 Well-Known
    Thank you for the understanding.
    I cannot use soft limits without hard limits switches, is that correct? This then would allow homing of the system and the soft and hard limits can work.
    Is that a correct definition?
  23. Peter Van Der Walt
    That Grbl WIki really is a must-read...
  24. GS76
    GS76 Well-Known
    You are right... My bad!
    I assumed!
    Thank you again for your assistance. I will make sure to book note the above from GitHub.
    Thank you again for the support and great software.
  25. David the swarfer
    then you need to do the 'fake-the-home' method, machiens always need a home
    How to 'Fake the home'
  26. GS76
    GS76 Well-Known
    Thank you, David, this is extremely helpful.
    Thank you again.
  27. JustinTime
    Is there a log file stored somewhere where I can see more info? I have an error all of a sudden (error 2, no response from the controller, closing port) and I want to see what can have caused it since the machine ran fine last time and I have not made any changes at all since then.
    I tired to update control, from 1.0.30 to 1.0.37, and my Teensy 4.1, running GRBLhal, and I still have the same error. I can connect and run the machine on IOSender. It shows no errors.
    #2697 JustinTime, Sep 1, 2024
  28. Peter Van Der Walt
    Teensy soft USB is troublesome with current CONTROL versions. Use IoSender
  29. NLucier
    NLucier New
    Machine sat for a few months with no activity and when CONTROL updated to 1.0.377, I seem to have lost any display updating of the machine's work coords. If I manually jog to a location and set zeros, jog away, and then gotozero, the machine does as expected and returns perfectly. However, the GUI does not show the current coords as the machine is moving around. Is there a new setting that it defaulted to something else that I need to return to an actually useful setting?
  30. Peter Van Der Walt
