replacement Y gantry plates for R7 CNC?
Discussion in 'CNC Mills/Routers' started by dprice, Jul 6, 2024.
  1. dprice
    dprice New
    The left y-axis jammed and the right side kept moving,,,,so now the y-gantry plates are bent so the machine is out of square and sometimes jams on y motion. I doubt I can bend them back to flat (1/4" aluminum plate) so I'm looking at replacement options.
    HobbyFab/SMW3D is gone but the files have been saved to GitHub (github.com/eclsnowman/R7-CNC) so one option is to find someone to cut them for me. This would be Plan A.
    Plan B would be to replace the plates with some combination of C beam plates and other hardware. I could use some insight on how to go about this since the R7 y gantry plates do not extend below the C beam. Any suggestions on where to start?
    A less than exact fix would be fine since I can always try to cut my own replacement plates once I am back up and running.
    Thanks!
    Don
  2. Rick 2.0
    Use your good one as a template to drill a temporary replacement. That'll get you up and running to make a proper set.
    dprice likes this.
    Otherwise send off the files to SendCutSend or similar services
    dprice and Rick 2.0 like this.
  4. dprice
    dprice New
    Excellent ideas. Plan C would be to add the base frame and use the Lead gantry design. That may make it easier to fix when I screw it up again.
