Power led indicator does not come on when I turn on the power switch.... Any ideas???
Discussion in 'General Talk' started by Bryant Hart, Jul 9, 2024.
Thread Status:
Not open for further replies.
  1. Bryant Hart
    When I flip the power switches on both the power source and the X32, I don't see the power led indicator light up. Is the x32 not coming on?? Also, my computer does not see the x32.
    Please provide pictures of wiring between BlackBox and PSU for review
  3. Bryant Hart
    Here are the connections I made
    1) Currently correct. Any chance it was wired incorrectly before and corrected already before the pictures were taken?
    2) Does the PSU start up if you unplug the BlackBox?
    3) Did you set the 115/230v switch on the PSU correctly?
  5. Bryant Hart
    1) Currently correct. Any chance it was wired incorrectly before and corrected already before the pictures were taken? Everything was connected as you see it
    2) Does the PSU start up if you unplug the BlackBox? The Red LED on the PSU stays on constant when the Black box is unplugged.
    Yes, the 115/230v switch is set to 115v
    Contact the Store via support.Openbuilds.com > for further assistance thanks
Thread Status:
