V1.0378 update
Discussion in 'OpenBuilds Bug Report' started by Lewis Trafford, Jul 16, 2024.
  1. Lewis Trafford
    I have just updated my X32 blackbox to the latest SW V1.0378 and since then I am unable to control my machine. The machine was Idle and not in use when the update started.
    OK thanks for the feedback, roll back to V1.0.376 please Release v1.0.376 · OpenBuilds/OpenBuilds-CONTROL
    Pulled V1.0.378 from the list, we are testing a new connection method to allow better operability with older controls as well, tricky one. Back to the drawing board
  3. Lewis Trafford
    Thanks for the speedy reply, silly question, how do I go about back dating once I've downloaded the Software?
    run the exe and install as usual
  5. Lewis Trafford
    Yep, complete brain fart. Thanks again.
  6. Keith Kimura
    I received and message to update CONTROL to the latest update and now it won't run jobs.
    This is what I get when connecting. Not sure what to do.
    [15:15:40] [ connect ] PORT INFO: Port is now open: COM8 - Attempting to detect Controller...
    [15:15:40] [ connect ] Attempting to detect Controller (1): (Autoreset)
    [15:15:40] [ ] ok
    [15:15:40] [ connect ] Attempting to detect Controller (2): (Ctrl+X)
    [15:15:40] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [15:15:44] [ connect ] Firmware Detected: grblHAL version 1.1f dated on COM8
  8. Keith Kimura
    Re-installed V1.0378 but am still having problems with Blackbox. It seems to make the connection but it isn't retrieving the GRBL. Here's what happens when I connect:
    [11:03:32] [ 3D Viewer ] WebGL Support found! success: this application will work optimally on this device!
    [11:03:32] [ websocket ] Bidirectional Websocket Interface Started Succesfully
    [11:03:33] [ update ] Checking for Updates
    [11:03:33] [ update ] You are already running OpenBuilds CONTROL 1.0.378
    [11:03:37] [ connect ] PORT INFO: Port is now open: COM8 - Attempting to detect Controller...
    [11:03:37] [ connect ] Attempting to detect Controller (1): (Autoreset)
    [11:03:37] [ ] ok
    [11:03:38] [ connect ] Attempting to detect Controller (2): (Ctrl+X)
    [11:03:38] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
    [11:03:41] [ connect ] Firmware Detected: grblHAL version 1.1f dated on COM8
    No,
    If you read that thread you'd see what you needed to do. Not REINSTALL the broken version, roll back to 1.0.376 (1.0.379 will be out soon to fix the issue too but for now roll back to what worked)
    We are not expecting V1.0.378 to fix itself, that's why we pulled it as soon as we got the first report of an issue (in the linked thread)
    Then while you are on V1.0.376, it gave us time to rewrite the code, pending a release later: V1.0.379 · OpenBuilds/OpenBuilds-CONTROL@5404220
  10. Keith Kimura
    Sorry, misunderstood the thread link. I will try again. Thank you.
  11. BillyTheClown
    My windows 11 PC downloaded and installed V1.0.138 today,
    now my machine lead 1010 with X32 will no longer jog,
    message when jogging - "Please wait for machine to be Idle, before jogging"
    1) Lightburn can home all axis with no problem,
    2) rebooted windows 11, and x32 (turned off power to all) press reset on x32
    Machine was last used Saturday July 13 with no issues
  12. BillyTheClown
    Downgraded to V1.0.376 and working again
  13. Levi R
    Levi R New
    I had the same issue, there also wasn't a Grbl settings tab
  15. BillyTheClown
    When V1.0.379 is ready to test, you can send me a link and I will install and test it for you
