Anyone know if there are lower-profile eccentric spacers available anywhere?
Discussion in 'General Talk' started by Borogove, Jul 23, 2024.
  1. Borogove
    Borogove New
    Hi! I'm a newb with linear rail systems, but I'm attempting to use it for a design that's firmly in the "Other Project" camp. Long story short, I'm finding that vertical space is something of an issue, and I would love to be able to swap the 6mm eccentric spacer nuts for something like a 2mm version of the same. I've found a couple leads online, but they all seem to taper off into dead ends. Does anyone know if something like this is available and where to find it? Thanks!
  2. Rick 2.0
    Have you tried Inventables?
  3. David the swarfer
    look for a local model train club, one of them can just turn them shorter on his lathe (-:
  4. Borogove
    Borogove New
    Actually, I did! They had a picture of one on the eccentric spacers listing, but when I called to ask about it, they said that was an older part that they don't carry anymore. They had pdf and stp files for the part, though, so that could potentially be useful.
  5. Borogove
    Borogove New
    Huh. My dad has a metal lathe - maybe I can try to work some magic there.
