How would you fasten Granite to a Modular Table?
Discussion in 'General Talk' started by dave_michigan, Jul 18, 2024.
Tags:
How would you fasten a Granite Slab to an Open Builds Modular Table?
  1. Epoxy
    100.0%
  2. Silocone Caulk
    0 vote(s)
    0.0%
  3. Tapcon Screws
    100.0%
  4. Sleeve Anchors
    0 vote(s)
    0.0%
  5. Dowel
    0 vote(s)
    0.0%
  6. Other
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. dave_michigan
    Let's say I have an extra slab or two or granite laying around, just hypothetically wanted to use it for an Open Builds Modular Table top, for a CNC machine.
    Would you drill holes into it and screw it into the table, or would you use epoxy or some other method to affix the granite to the table?
    Regards,
    Dave
    Granite/marble Kitchen countertops usually just gets a couple dabs of silicon to stop them sliding and the weight does the rest :)
    JustinTime likes this.
  3. JustinTime
    As Peter said but maybe use construction adhesive, also known as liquid nails, instead of the silicone.
  4. dave_michigan
    Thanks for all your help!
    I think it looks pretty good. Next step is to get the C-BEAM built and installed.
    I ended up going with Gorilla Glue construction adhesive.
    #4 dave_michigan, Jul 23, 2024
