Software not working
Discussion in 'General Talk' started by Jon57, Aug 6, 2024.
  1. Jon57
    Jon57 New
    Running a C-beam XL with blackbox 32 controller, had it running and shut down for the night. Next day the steppers wont move in any direction, can not zero the controller program, limits wont work, touch plate wont work but blackbox is on and seems to be ok. help
    Accidentally wiped your Grbl Settings? Restore last good backup. If you forgot to backup, load fresh profile. Both actions available on Grbl Settings tab
    Alternatively PSU on and working? Fan in BlackBox spinning? If not, you aren't supplying 24v power.
    To spin motors you just need power and correct Grbl Settings
