Interface wifi issue
Discussion in 'CNC Mills/Routers' started by PickleRick, Aug 14, 2024.
  1. PickleRick
    Just got my Lead 1515 up and running and did the update on the interface for v1.58 and following the update on boot up the wifi times out for connecting and then the homescreen says not connected and 0.0.0.0 in the upper R corner? Also it doesn't populate as a wifi connection on my phone to try and setup the wifi like originally done? Any ideas?
  2. PickleRick
    I figured it out
  4. PickleRick
    Exactly what I did, thank you. I didn't see it anywhere in the docs that after doing firmware updates that you need to do the wifi again but figured it was worth a try lol
