OpenBuilds CAM Software
Discussion in 'CAM' started by Mark Carew, Oct 8, 2018.
  1. KEN MACDONALD
    I've been trying this out today on my MacBook Pro. Two things to note. 1. It doesn't seem to run very well in Safari 2. On a Mac when selecting you use the 'alt' key not the 'ctrl' key. That's as far as I have got. Just getting my head around inside cuts, outside cuts and pockets etc.
  2. SI HIHOT
    SI HIHOT New
    Dzień dobry rozpoczynający się z openbuilds cam. Posiadam projekt do wycięcia laserem pliku svg i cad, po wrzuceniu projektu do programu i zaznaczeniu kilku czynności i utworzeniu nazwy nazwy i jak laser może wywołać wyskakuje mi taki komunikat. „Wystąpił błąd:TypeError: Nie można odczytać właściwości nieznanych (odczyt „dzieci”)”. Prosze o pomoc i mogą jakieś materiały dla absolwentów (posiadanie szkoleń z programów)???. Posiadam maszynę LEAD 1010. Może mam ustawienia złe pod maszyną. Już opadnięte ręce.
    English only please, see section 15 of the terms you agreed to during registration: Terms of Service and Rules | OpenBuilds
  4. SI HIHOT
    SI HIHOT New
    Good morning starting with openbuilds cam. I have a project to cut an SVG and CAD file with a laser, after uploading the project to the program and selecting a few activities and creating a name, name and how the laser can be called, this message pops up. "Error: TypeError: Unable to read unknown properties (reading 'children')." I am asking for help and some documents for graduates (possessing qualifications from programs)??? I have a LEAD 1010 machine. Maybe my settings are wrong on the machine. My hands are already slumped.
  6. Beeworks
    Beeworks New
    Hello, I hadn't used my lead1515 in a while, had to reboot the laptop and reinstall controll etc... but now that I'm setting it up again I have an issue with the Z axis when I run a job ( I use it for plasma cutting)
    I don't have a Z-probe so I always set xyz 0 manually. But when I do this now and run the job, the head moves to the right x-y space and then proceeds to plunge in Z way beyond point 0 until it gives an alarm about not finding the Z-probe.
    The only place I can find anything about a Z probe setting is in Openbuilds CAM settings under "Plasma: Touch Off Sequence" which has as a setting
    "G38.2 Z-30 F500; Touch off Probe
    G10 L20 Z-3; Set Z Zero"
    I have no idea if that is the issue and what I'm supposed to enter in the box to stop it from looking for the Z-probe.
  7. David the swarfer
    you dont have a probe so you must turn off the touch off sequence.
    Beeworks likes this.
  8. KanakaMission
    Hey guys Im having trouble with importing .dxf files into open builds cam, Ive tried every .dxf file format r12 r13 r14 also used dxf. file convertors and still getting dimensions wrong or errors on open vectors Im missing something and I don't know what it is? I have looked through the help pages etc and I am doing what is documented but not getting any luck. Exported the same file from solid works and from fusion 360 and haven't made any ground.
  10. KanakaMission
    Ok yes I believe its closed just a simple triangular part ill upload the file now
  11. KanakaMission
    Yes Ill use fusion to run the cam but right now Im sharing the machine with a guy that has solidworks so open builds cam will be best we can both use the machine with open builds CAM
  12. Ernet
    Ernet New
    Hi Peter,
    I am new to Openbuilds cam and used the link in your post to learn more. I cannot access the library, my cam only gives me an option to open a drawing and does not give me a dropdown as per the demo in the link.
    Please advice what i am doing wrong
    Been a couple years since that post, the library has since been replaced with the Insert > Icons option
    that gives you a tonne more than the library had
    But mainly CAM is a "cam" not a CAD, we provide some very basic get-you-started drawing tools, but you may want to do the drawings in a proper CAD eventually then bring it here to convert to gcode (the main function of a CAM) - see the CAD > CAM > CONTROL concept docs:software:overview [OpenBuilds Documentation]
    Ernet likes this.
  14. sergiomajluf
    sergiomajluf Well-Known
    My latest update was from 1.0.376 to 1.0.388 and I'm runing CONTORL on a linux machine with Lubuntu. It runs well but, on the last update, something changed in the UI and now I can't acces the lower part of the window.
    I tested CONTROL on my Mac and realized there is a minimum permited height for the window size (aroun 850pixels if I'm right), and you cannot resize it shorter than that. This means I can't acess the toolbar for simulation, nor the lower status bar with connection status, Job Que and so forth.
    ¿Is this something we can address at future updates please?
  15. David the swarfer
    press CTRL and - to shrink the contents of the display, just like in a browser. CTRL 0 to returbn to normal, CTRL + to make it bigger
  16. sergiomajluf
    Thanks, but that doesn't work, because it changes the rendering scale of elements within the chrome/container. The issue here is that the outer container is contrained to a min-height.
    As a bouns bug (didn't wanna call it that, but couldn't think of a better term) the Full Screen button in the upper right part of the toolbar doesn't work either, nor mac nor linux. Haven't tested on windows yet
    #286 sergiomajluf, Feb 28, 2025
