z axis wont go up
Discussion in 'OpenBuilds Bug Report' started by cabrasauce, Sep 9, 2024.
  1. cabrasauce
    z axis goes down fine but then it can only go up about a quarter inch before it make a grinding noise and it wont go up any further. I checked a post saying check the wiring and
    "Grubscrews on shaft coupler rattled loose causing mechanical slippage when working harder to lift the Z axis"
    but they seem fine.
    I'm trying to move it by hand back to the top with the motor removed but am unsuccessful so I can look at the bottom half of the screw.
  3. cabrasauce
    found it, it was actually a screw that had backed out and would push against the rail going upward but not down.
  4. IowaCC
    IowaCC New
    How did you end up taking everything off to get to that screw? i have the same problem at the moment and dont want to dig to deep into tear apart
