Cannot upload jog control widget?
Discussion in 'CNC Mills/Routers' started by Ray Kowerchuk, Feb 22, 2023.
  1. Ray Kowerchuk
    Hi, I have tried to download the widget on my iPhone and iPad with no result. Thanks for any idea what is wrong.
    Make sure your computer firewall allows the webserver to be open
    Make sure your phone and computer is on the same network and can see each other
    Make sure you have the correct IP for the PC - and enter it into a browser on the Phone
  3. Ray Kowerchuk
    Hi and thank you for the very quick reply. Darn Firewall, as soon as I shut it off it downloaded. THANK YOU!
    :) Setup an 'allow' for CONTROL and turn it back on - just in case! :)
    Firewall rule: Local PC IP on ports 3000 and 3001 for TCP.
  5. James S
    James S New
    Hello All, Can someone help with this
    Trying to use job widget but getting error on Phone. When I scan the QR Code on PC OPenbuilds Control Software I get this error.
    Error: ENDENT: no such file or directory, open 'C:\User\jamie\AppData\Local\Temp\C04a0a81..... tmp.html'
    Both PC, Phone and Controller on same network. Has been working in the past.
    Thanks !!
    Is the QR code itself not showing? Skip the QR and just type the IP of your PC into the browser http://computer'sipaddresshere:3000/jog on the phone
    Also shown above the QR code on same window, if you checkout the screen. QR idea just to save a bit of typing but if its not working on your setup, the URL can still be typed. QR is just same URL converted to QR.
    Or is QR working but page after not loading: If your PC has multiple local IPs pick the right one, make sure no other applications are conflicting on port 3000 etc. Make sure its the correct IP, correct LAN,etc
    Still works fine on CONTROL v1.0.376 on a healthy computer/network:
  7. James S
    James S New
    Thanks Peter for the quick response. Typing IP didn't help.. Restated PC and scanned QR and worked. Guess port was not working..
