Blackbox x32 maximum speed/feed rate?
Discussion in 'Controller Boards' started by Ramy Y, Sep 18, 2024.
  1. Ramy Y
    Ramy Y New
    Hi, I have a little CNC machine, that has a grbl controller on it.
    When I update the grbl feed/speeds, it won't go above 4000/min.
    I'm guessing this hard limit is baked into the firmware. If I buy a different controller and connect the motors/limit switches to it, will I still have this issue? (is it a grbl limit?)
    I was looking into upgrading the motors, but I don't think it'd change much if there's a limit on the board.
    Also, would this help at all if i were to getting it running or is there other things I need to consider?
    (the machine is a 4040/4060-pro)
    Thank you all, any help is greatly appreciated.
    No its configurable Grbl v1.1 Configuration
    But you will reach a ceiling of the stepper drivers, motors, linear components top speed - whereafter it stall out. True for any combination of machine hardware and electronics.
    Low inductance motors = faster RPM (Like our motors are 1-2mH great match for our controllers)
  3. Ramy Y
    Ramy Y New
    Just to be clear, I will still be getting this error unless I upgrade the motors/drivers as well as the controller?
    >>> $110 = 5000.000
    [Error] An error was detected while sending '$110 = 5000.000': (error:12) Grbl '$' setting value cause the step rate to exceed the maximum supported. Streaming has been paused.
    grblHAL on a BlackBox X32 has a higher step rate (different from Max Rate) so will help, but theres a mechanical design issue at play:
    That means you have some very high resolution mechanicals? Very high steps per mm value needed for the pitch of the drive system? If it needs a lot of steps to move a certain distance, thats limiting your top speeds too.
    Grbl Settings backup and details of linear system (leadscrew specs like pitches and starts)
  5. Ramy Y
    Ramy Y New
    Thank you very much for your help, here's what I could find:
    GRBL Settings:
    $0 = 10 (step pulse,usec)
    $1 = 255 (step idle delay,msec)
    $2 = 0 (stepport invert mask)
    $3 = 4 (dirport invert mask)
    $4 = 0 (stepenable invert,bool)
    $5 = 1 (lims pin invert,bool)
    $6 = 1 (probe pin invert,bool)
    $10 = 3 (status report mask)
    $11 = 0.010 (junction deviation)
    $12 = 0.002 (arc tolerance,mm)
    $13 = 0 (report inches,bool)
    $20 = 0 (soft limits,bool)
    $21 = 1 (hard limits,bool)
    $22 = 1 (home cycle,bool)
    $23 = 3 (homing dir invert mask)
    $24 = 100.000 (homing feed,mm/min)
    $25 = 500.000 (homing seek,mm/min)
    $26 = 250 (homing debounce,msec)
    $27 = 2.000 (homing pull-off,mm)
    $30 = 10000 (maximum spindle speed,rpm)
    $31 = 0 (minimum spindle speed,rpm)
    $32 = 0 (laser mode enable,bool)
    $100 = 800.000 (X axis pulse:step/mm)
    $101 = 800.000 (Y axis pulse:step/mm)
    $102 = 800.000 (Z axis pulse:step/mm)
    $103 = 177.777 (A axis pulse:step/mm)
    $110 = 4000.000 (X axis max rata:mm/min)
    $111 = 4000.000 (Y axis max rata:mm/min)
    $112 = 4000.000 (Z axis max rata:mm/min)
    $113 = 1000.000 (A axis max rata:mm/min)
    $120 = 100.000 (X axis acceleration:mm/s^2)
    $121 = 100.000 (Y axis acceleration:mm/s^2)
    $122 = 100.000 (Z axis acceleration:mm/s^2)
    $123 = 20.000 (A axis acceleration:mm/s^2)
    $130 = 400.000 (X aixs max travel:mm)
    $131 = 400.000 (Y aixs max travel:mm)
    $132 = 80.000 (Z aixs max travel:mm)
    $133 = 9999.000 (A aixs max travel:mm)
    ok
    800 steps = 2mm pitch (our leadscrews are faster, 8mm pitch (200 steps) for example)
    On the other hand, they say its a "32bit" microcontroller, but firmware setting is older grbl, so some kind of 32bit fork monstrosity not standard Grbl either. So not ideal - weird non standard stuff. You'd expect old grbl on an 8 bit ATmega, or if its 32 bit you'd expect one of the newer firmwares like grblHAL or FluidNC
    Keep in mind though, mechanically you might stall a little over 4000 anyway, even our LEAD machines have conservative settings set at 3500mm/min
    Ramy Y likes this.
  7. Ramy Y
    Ramy Y New
    I have a LEAD1010 (I love it!) at a shared space, but I already had this little one first for my garage at home.
    You're right, that's definitely not worth if I have to change all that. Was just seeing if there was any hope for it haha.
    Thanks again for your help.
