blackbox x32 continuous jog function
Discussion in 'CNC Mills/Routers' started by Fastbass, Oct 3, 2024.
  1. Fastbass
    Fastbass New
    Machine is a quenbe pro 1015 with x32 controller, just setting it up but on continuous jog it only moves 6 inches or so then stops and have to jog it again... rinse and repeat to move entire distance, I'm new to this so I'm sure its my stupidity at work here but any help would be greatly appreciated. thanks
    1) Setup steps per mm correctly (without Soft limits Enabled - it will move 1000mm per click max) - calibration must be far off if 1000mm looks like 6 inches
    2) Also setup Homing, Max Travel and Soft Limits (Continuous honors the entire config and moves the entire - now known thanks to homing and max travel) Machine Coordinate Space without reclicks
    Read Grbl v1.1 Configuration
