An old Ox needs help with move to blackbox32
Discussion in 'CNC Mills/Routers' started by Ted Ellison, Oct 3, 2024.
  1. Ted Ellison
    Ok, I have an old ox machine that has been running using tinyg v8 and chilipepper. I decided to move to a newer controller and almost have things working. The last step is to get my 300w quiet spindle working. I can get it to spin up using the variable speed control knob but nothing when using pwm from the blackbox.
    I'm hoping that the problem is with the jrbl settings but I don't seem to be smart enough to get them set correctly. I've been stubbornly working on this for over a week, even ordering a replacement pwm controller.
    If I measure the voltage at the pmw controller I always get 10 volts no matter the speed I send (mm3 s12000 or m3 s5000).
    It's tough to live with stupidity, so any help you guys can provide is greatly appreciated.
    Thanks,
    Ted
    PWM output is 3.3v. If you wired the PWM output to a 0-10v input, it would have been damaged, explaining the always on state.
    Can also be damaged by shorts, or backfed voltage from a spindle controller. Sadly if the damage is done, there's nothing you can do
    Pwm or 0-10 = two different signals entirely and important to use the correct one the spindle controller needs. Also double check spindle controller has no stray voltages present at its input, those cheap modified PSUs are quite notorious
  3. Ted Ellison
    Thank you Peter. I'll do all that you suggest. I realize you guys have moved on from these spindles and perhaps I will eventually do that as well. In the meantime is there somewhere that I can get information on the correct grbl settings and wiring to operate one of these cheap spindles?
    The pwm board that I have (actually have two) properly controls the motor speed using their speed control knob and changing the jumper.
    As soon as I can I'll check what's going on with my wiring between the blackbox pwk terminal and the pwm board.
    Again all help is appreciated.
    Ted
    Search on forum here should have some, Grbl settings = stock default. Wiring = whatever the spindle documentation tells you
  5. Ted Ellison
    Hello Peter,
    I was able to go out to my machine and make new measurements. I disconnected the pwm wires from the pwm controller. When I then tested the voltage coming from the blackbox pwm connectors I get 10v. What am I doing wron? Should be about 3.3v I believe.
    Thanks,
    Ted
  6. Ted Ellison
    I notice in the blackbox specifications it says pwm output for laser modules. Only for laser modules? What about dc spindles?
    How sure are you you are measuring the correct terminals?
    "DC spindles" (various models, various inputs, various levels of quality) - some might accept 3.3v PWM, some needs a 0-10v signal, some needs 5V PWM, etc. Usually labelled or documented on 'spindle' PSU
  8. Ted Ellison
    When I issue an m3 command I can hear, I believe, the relay click. I see in the documentation there are jumpers to disable the relay and send pwm out the pwm connection. When I open the blackbox I only see a couple jumpers. No relay jumpers. What am I missing?
    Thanks,
    Ted
    The older BlackBox 4X Documentation?
    Sounds more like a newer BlackBox X32 (read the right one's docs)
    On the X32:
    Relay1 = tool enable
    Relay2 = spindle direction
    PWM is seperate output
    Review docs:blackbox-x32:layout [OpenBuilds Documentation] to learn more about what's where
  10. Ted Ellison
    Thats the old 4X docs
    X32 does not have all those sections (Slave driver not a jumper anymore, relay not a jumper anymore, RGB LED removed as X32 has a Blue fixed color fan now, etc)
    Plus, you've checked inside, it doesn't have those jumpers...
  12. Ted Ellison
    I'm extremely frustrated by now. I jumped on the forum looking for help.
    I feel as though I am being punished for wanting to use a "cheap dc spindle and cheap unreliable pwm board from china".
    So is it possible to use a DC spindle? If so, how about some help instead of using your punishment insults.
    You must be in marketing as you continue to push all of your new products.
    I liked what I saw with control and decided to try it so I purchased your blackbox. Quite honestly, doesn't do much more than a tinyg v8 except it has its own fan and runs more current grbl.
    Ted
    It is, IF the controller is wired to the controller correctly (0-10v vs PWM depending on what that spindle needs as there are different versions out there) AND if the spindle controller didn't cause damage (sadly they are notorious, so its always a possibility)
    If it didn't malfunction, and you didn't accidentally wire it up wrong, it should still be salvageable.
    Speaking of help, you never really answered my question in your other thread:
    (we should probably move these posts in there, didn't even realise its you as I started to reply to new thread, best to keep conversations in one thread)
    The one about are you sure you are measuring the correct output? Can't see 10v on the PWM port thats sort of impossible (if you had enough damage that a 10v signal is coming out of the 3.3v ports the microcontroller would be so fried it would be completely dead) - pretty sure that you are measuring the 0-10v port not the PWM port
    Then the next question would have been pics of the spindle controller to see if it needs PWM or 0-10v and then you just had to wire up the correct one.
    I am still fearful that there was damage as the 10v (even if measured at the 0-10v port) is not changing, so if you did have any incorrect wiring (like wiring a 0-10v spindle input to a 3.3v PWM or the other way round 3.3v PWM input to the 0-10v output) it might still have damage
    Most of those PSUs for the DC motor spindles have onboard input, what is this PWM board then?
