custom setting
Discussion in 'Other Builds' started by Gigooser, Oct 27, 2024.
  1. Gigooser
    Gigooser New
    trying figure out how to set up a custom plasma table. i have open build controller x32
    4-nema 23 motors, rack and pinion x and y drives and ball screw z axis. trying to figure out where to put in gear info to be able to calibrate to correct measurements.
  3. David the swarfer
    you don't need to know the gear ratios.....
    Just put in 1 for steps/mm then command a move of 1600mm (200step per rev * 8 microsteps, default for BB),
    G1 X1600 F1600
    that should turn the motor 1 revolution over a minute. Measure how far the carriage moved.
    now you can calcuate steps/mm using
    newstep/mm = currentstep/mm * commanddist / actualdist
    newsteps/mm = 1 * 1600 / distancemeasured
    set the steps/mm to that value (do and X and Y the same) , reset the BB and then refine the value using the calibration wizard in CONTROL.
  4. Gigooser
    Gigooser New
    ty ill try that.
