OpenBuilds LEAD CNC Machine 1515 (60" x 60")
Discussion in 'CNC Mills/Routers' started by OpenBuilds, Sep 29, 2020.
  1. Evilspawn
    Evilspawn New
    Is there any recommendation for a spindle which will work best with the 1515?
    We highly recommend RoutER11 CNC Kit
  3. Evilspawn
    Evilspawn New
    Oh, I already have that one. I'm talking about an actual spindle not a trim router motor.
    VFD spindles are often troublesome (hard to setup, cheap VFDs lack filtering that cause EMI issues and even damage controllers, not as reliable as you think, race to the bottom often leaving you with bearing and runout issues)
    Thus, no, we don't have a recommendation.
  5. Ray Warner
    I like the structure and rigidity of the LEAD 1515, but due to shop space that size is not an option. I am considering a 1575x900 foot print machine. I will need to tilt the machine, about 31degrees from the wall, to fit my space. I would use the higher torque steppers for the Y-axis. Am I out in left field with my plans, or is it doable?
  7. David the swarfer
    love that!
    now i need one... or more...
  8. James K. Rivera
    I realize this is an older post, but I was trying to look at the CAD model. It is all in Sketchup, which I think was a downloadable client when this was posted, but the free version is now a website client and this model is too big to be usable. Is there any chance you could export it to STEP files? I'd like to view it in FreeCAD. Even a single huge STEP file would be useful. Thanks!
    We still have it https://builds.openbuilds.com/mirror/sketchup/
  10. James K. Rivera
    You, sir, are AWESOME! Got it. Installed it. Viewed it. Exported it...as DAE and OBJ. The former gives a bajillion STL meshes and the latter gives one ginormous mesh. There is no STP/STEP option. Oh well, with Sketchup installed I can at least view it and answer my questions regarding how it is all put together and dimensions. Thanks!!!
  11. Ehask71
    Ehask71 New
    What is the dimension on the mdf strips? Im copying you :)
  12. Oun Hasan
    Oun Hasan New
    hi there
    i`m facing a problem with 1515 CNC while operating
    a massage appears : (ALARM code:1 hard limit triggered )
    i try to slow the feed rate but still same error occurs
    all the limit switches are working fine while homing
    any one have any idea?
    also i need to join new wireless but i can`t
    thanks
    At the time the alarm comes up, is the machine touching any switches? If not, it could be a false trigger caused by EMI. Do you have a dust extractor (Surfacing creates a lot more chips): docs:blackbox-x32:faq-emi [OpenBuilds Documentation]
    docs:interface:wifi-setup-nextgen [OpenBuilds Documentation] - making sure your firmware is up to date firmware/interface/CHANGELOG.txt at main · OpenBuilds/firmware (Should be on v1.58) otherwise update first docs:interface:firmware-update-control [OpenBuilds Documentation]
  14. Oun Hasan
    Oun Hasan New
    thanks for your support
    i will read these instructions and will try again
