Torch slows and goes off
Discussion in 'Laser Cutters' started by Gus Mcfarland, Nov 9, 2024.
  1. Gus Mcfarland
    I biult an JDs garage CNC plasma table.I have it working and am trying to cut some dog shapes out of .0125"
    some setting in Setup or Post or Possibly Tool setup.When i open in OpenBiulds The paths have Mostly blue lines with sections of red in curves.When the torch slows it goes off.
    I am useing Fusion and OpenBiulds Post.No ARCS[​IMG]
  2. Misterg
    Misterg Veteran
    What is the value of your $32 setting? (Laser mode)
    If it is enabled (1) set it to disabled (0).
    Extinguishing arc is usually related to
    - air pressure too high
    - worn consumables
    - cut height too high
    - wrong consumables (using drag cutting with a clear cut nozzle or cutting high with a drag nozzle)
  4. Gus Mcfarland
    The torch goes out because it's 1/8 and when it slows it runs out of metal and goes off.
    It has been cutting fine with square and circles .
    I was cutting 3/16 and when it slowed in the curves it was not a problem but when I dropped to 1/8 the torch would go off in the curves.
    I un checked the ARCS box and it cut fine.
    Now with these new shapes I am having problems.
    What can I do to help you All to help Me?
  5. Gus Mcfarland
    The G-Coad has these sections of short jogs what did i do wrong?
    (Made in : Autodesk CAM Post Processor)
    (G-Code optimized for Grbl 1.1 / BlackBox controller)
    (OpenBuilds CNC : GRBL/BlackBox)
    (Post-Processor : OpenbuildsFusion360PostGrbl.cps V1.0.42)
    (Units = mm)
    (Laser UseZ = false)
    (Laser UsePierce = false)
    (Arcs are limited to the XY plane: if you want vertical arcs then)
    (edit allowedCircularPlanes in the CPS file)
    (Drawing name : Meerkat4 v2)
    (Program Name : Meerkat 4)
    (1 Operation :)
    (1 : 2D Profile1)
    ( Work Coordinate System : G54)
    ( Tool 2: Plasma Cutter Diam = 25.4mm)
    ( Machining time : 0h:0m:50s)
    G90 G94 G17
    G21
    (Plasma pierce height 4)
    (Plasma topHeight 3)
    (Operation 1 of 1 : 2D Profile1)
    G54
    (Plasma cutting with GRBL.)
    (Using torch height probe and pierce delay.)
    (This relies on homing, see Search Results for Query: G53 fusion | OpenBuilds )
    G53 G0 Z10
    G0 X80.776 Y45.363 F1000
    G0 X80.776 Y45.363 Z45
    G38.2 Z-30 F100
    G10 L20 Z-2.5
    G0 X80.776 Y45.363 ; force position after probe
    Z4
    M3 S1000
    G4 P1.8
    G1 Z3 F1000
    G1 X77.039 Y46.788
    G3 X76.495 Y43.803 I6.29 J-2.688
    X77.325 Y41.016 I7.795 J0.803
    X79.579 Y37.323 I22.814 J11.393
    X81.379 Y34.909 I21.947 J14.492
    X82.984 Y33.638 I4.113 J3.544
    X85.199 Y33.306 I1.708 J3.848
    G2 X86.648 Y33.201 I0.354 J-5.145
    G1 X86.74 Y33.179
    G2 X89.191 Y31.987 I-1.777 J-6.772
    X91.156 Y30.487 I-23.21 J-32.443
    X92.451 Y29.477 I-4.636 J-7.284
    X92.763 Y29.105 I-3.013 J-2.84
    G1 X92.818 Y29.027
    X92.925 Y28.86
    X92.979 Y28.766
    X93.067 Y28.589
    X93.114 Y28.477
    X93.18 Y28.29
    X93.2 Y28.228
    X93.215 Y28.165
    X93.258 Y27.966
    X93.269 Y27.9
    X93.277 Y27.832
    X93.292 Y27.622
    X93.295 Y27.555
    X93.293 Y27.488
    X93.28 Y27.266
    X93.274 Y27.202
    X93.264 Y27.139
    X93.219 Y26.903
    X93.191 Y26.79
    X93.112 Y26.54
    X93.076 Y26.442
    G2 X92.006 Y24.458 I-9.514 J3.85
    X91.648 Y24.062 I-4.378 J3.59
    G1 X91.585 Y24.001
    X91.413 Y23.85
    X91.338 Y23.79
    X91.149 Y23.654
    X91.066 Y23.6
    X90.857 Y23.479
    X90.768 Y23.433
    X90.538 Y23.329
    X90.448 Y23.293
    X90.195 Y23.207
    X90.106 Y23.181
    G2 X89.396 Y23.045 I-1.209 J4.387
    X82.979 Y22.473 I-11.848 J96.567
    X78.759 Y22.615 I-1.182 J27.529
    X74.582 Y23.791 I1.572 J13.595
    X70.087 Y27.99 I4.721 J9.557
    X68.15 Y32.754 I14.647 J8.732
    X67.576 Y35.361 I25.175 J6.909
    G3 X66.876 Y36.988 I-6.99 J-2.041
    G2 X66.219 Y38.164 I112.863 J63.843
    G1 X64.175 Y36.026
    X62.127 Y33.892
    G3 X57.57 Y28.711 I53.414 J-51.57
    X56.683 Y26.801 I4.225 J-3.123
    X56.44 Y23.065 I10.553 J-2.564
    X58.82 Y15.738 I16.778 J1.401
    X60.433 Y13.799 I8.316 J5.277
    X61.43 Y13.071 I5.308 J6.228
    G2 X65.448 Y7.67 I-6.207 J-8.812
    X66.175 Y4.334 I-11.862 J-4.333
    G1 X66.174 Y4.239
    X66.167 Y3.915
    X66.16 Y3.814
    X66.124 Y3.511
    X66.105 Y3.407
    X66.04 Y3.124
    X66.01 Y3.02
    X65.919 Y2.757
    X65.877 Y2.656
    X65.762 Y2.412
    X65.711 Y2.318
    X65.572 Y2.093
    X65.514 Y2.009
    X65.356 Y1.801
    X65.293 Y1.727
    X65.116 Y1.536
    X65.052 Y1.473
    G2 X62.489 Y0.203 I-3.515 J3.87
    X59.77 Y0.087 I-1.642 J6.568
    G1 X59.665 Y0.123
    X59.557 Y0.158
    X59.476 Y0.189
    X59.385 Y0.229
    X59.299 Y0.278
    X59.245 Y0.312
    X59.19 Y0.35
    X59.137 Y0.392
    G3 X56.52 Y1.872 I-5.104 J-5.97
    X54.096 Y2.718 I-17.652 J-46.688
    G2 X51.172 Y4.005 I4.726 J14.707
    X47.801 Y8.477 I3.777 J6.353
    G3 X46.621 Y11.948 I-154.748 J-50.672
    G2 X46.032 Y14.974 I12.627 J4.027
    X46.063 Y16.521 I15.078 J0.478
    G3 X45.855 Y19.948 I-24.896 J0.21
    G2 X45.496 Y23.585 I62.621 J8.009
    G3 X44.938 Y28.793 I-29.238 J-0.501
    X43.316 Y33.231 I-15.986 J-3.328
    X38.285 Y38.061 I-10.566 J-5.969
    X32.68 Y39.922 I-8.743 J-16.958
    G2 X28.951 Y40.876 I3.928 J23.125
    X23.826 Y43.292 I10.853 J29.67
    X18.117 Y46.855 I54.009 J92.874
    X15.298 Y48.641 I52.57 J86.107
    X8.7 Y56.23 I11.895 J17.005
    X6.531 Y61.676 I24.453 J12.892
    G1 X5.406 Y65.653
    X4.271 Y69.627
    G3 X1.267 Y77.941 I-73.973 J-22.024
    X0.101 Y80.441 I-67.073 J-29.773
    G2 X1.297 Y81.833 I0.899 J0.437
    X6.163 Y79.597 I-4.746 J-16.742
    X10.339 Y74.59 I-7.184 J-10.237
    X13.703 Y66.587 I-109.08 J-50.558
    X14.836 Y63.168 I-105.849 J-36.97
    G3 X20.957 Y54.87 I16.386 J5.68
    X26.408 Y51.745 I16.331 J22.167
    X30.991 Y49.905 I24.361 J54.061
    G1 X34.149 Y48.776
    G3 X36.279 Y48.452 I1.78 J4.542
    X37.005 Y48.74 I-0.265 J1.728
    X37.592 Y49.851 I-1.042 J1.26
    X37.536 Y51.791 I-5.177 J0.822
    G2 X36.438 Y68.878 I82.332 J13.867
    X37.621 Y82.333 I124.673 J-4.177
    X39.201 Y92.338 I227.567 J-30.812
    G1 X39.795 Y95.656
    X40.406 Y98.976
    X41.623 Y105.605
    X42.818 Y112.377
    X43.982 Y119.158
    X46.285 Y132.729
    X47.454 Y139.51
    G2 X51.696 Y162.127 I766.561 J-132.036
    X56.728 Y182.633 I388.324 J-84.426
    G1 X58.628 Y189.714
    X60.521 Y196.798
    G3 X61.325 Y203.866 I-25.284 J6.457
    X61.045 Y206.781 I-43.079 J-2.671
    G2 X60.867 Y212.796 I37.869 J4.129
    X61.634 Y216.861 I17.443 J-1.185
    X66.267 Y222.676 I10.239 J-3.406
    X70.191 Y224.527 I9.372 J-14.783
    X75.268 Y225.883 I11.852 J-34.179
    X85.791 Y227.291 I14.105 J-65.383
    X93.439 Y226.891 I1.697 J-40.84
    X105.818 Y222.063 I-4.647 J-30.2
    G3 X109.979 Y220.9 I4.579 J8.351
    X113.25 Y220.922 I1.517 J16.992
    G2 X115.762 Y220.835 I0.94 J-9.132
    X117.121 Y220.242 I-0.984 J-4.11
    G1 X117.188 Y220.188
    G2 X118.477 Y218.353 I-2.291 J-2.979
    X118.511 Y213.782 I-6.293 J-2.333
    X116.592 Y210.512 I-8.569 J2.831
    G1 X113.068 Y206.463
    X109.533 Y202.422
    X105.988 Y198.39
    G2 X98.958 Y190.927 I-162.577 J146.08
    G3 X95.902 Y186.518 I11.591 J-11.301
    X95.046 Y179.923 I10.954 J-4.775
    X95.583 Y177.407 I15.796 J2.058
    G2 X96.916 Y172.792 I-121.68 J-37.645
    X97.499 Y168.52 I-17.504 J-4.566
    G3 X97.469 Y163.226 I43.156 J-2.892
    X102.15 Y148.196 I33.352 J2.143
    X107.061 Y141.457 I37.142 J21.906
    G2 X113.695 Y132.16 I-42.384 J-37.258
    X117.91 Y121.496 I-37.608 J-21.031
    X118.623 Y117.751 I-50.32 J-11.527
    G3 X119.996 Y114.227 I12.766 J2.942
    G1 X120.416 Y113.44
    G2 X122.405 Y109.762 I-49.686 J-29.254
    X123.555 Y105.95 I-11.969 J-5.688
    X123.455 Y102.744 I-12.409 J-1.217
    G1 X122.938 Y98.811
    G2 X121.034 Y98.524 I-0.992 J0.123
    G3 X118.764 Y102.372 I-15.289 J-6.423
    X114.565 Y105.105 I-6.624 J-5.587
    G1 X114.238 Y105.225
    X114.142 Y105.266
    X113.842 Y105.412
    X113.755 Y105.46
    X113.481 Y105.629
    X113.398 Y105.686
    X113.147 Y105.878
    X113.071 Y105.943
    X112.843 Y106.157
    X112.781 Y106.22
    G2 X111.468 Y108.529 I4.484 J4.078
    X110.684 Y111.27 I28.721 J9.701
    G3 X108.58 Y118.395 I-132.867 J-35.363
    X106.796 Y122.646 I-32.798 J-11.261
    X102.627 Y128.092 I-18.611 J-9.93
    X97.564 Y132.434 I-41.23 J-42.946
    X94.836 Y134.576 I-73.598 J-90.947
    X94.204 Y131.393 I7.83 J-3.207
    X95.717 Y128.121 I4.799 J0.232
    X97.553 Y126.729 I6.068 J6.098
    G2 X103.473 Y122.035 I-13.727 J-23.391
    X109.092 Y109.595 I-15.539 J-14.509
    X109.269 Y106.887 I-24.238 J-2.942
    G3 X110.453 Y103.341 I8.574 J0.892
    X111.997 Y100.768 I33.508 J18.359
    G2 X113.651 Y97.555 I-15.694 J-10.108
    X114.008 Y96.35 I-12.331 J-4.308
    G1 X114.03 Y96.233
    X114.038 Y96.114
    X114.032 Y95.995
    X114.012 Y95.878
    X113.978 Y95.764
    X113.931 Y95.654
    X113.871 Y95.551
    X113.8 Y95.456
    X113.718 Y95.37
    X113.626 Y95.295
    X113.525 Y95.231
    X113.418 Y95.179
    X113.306 Y95.14
    X113.189 Y95.115
    X113.071 Y95.104
    X112.952 Y95.107
    X112.834 Y95.125
    G2 X106.532 Y97.328 I3.799 J20.978
    X101.55 Y101.833 I7.347 J13.132
    X98.966 Y107.824 I14.693 J9.891
    G3 X98.583 Y109.275 I-12.147 J-2.432
    X96.576 Y111.63 I-4.52 J-1.819
    X93.937 Y112.955 I-7.283 J-11.222
    G1 X93.325 Y113.204
    X93.237 Y113.238
    G2 X91.824 Y105.685 I-78.314 J10.739
    G3 X89.895 Y97.167 I322.301 J-77.474
    X88.876 Y89.736 I54.198 J-11.214
    X89.222 Y82.665 I33.152 J-1.926
    X90.076 Y78.833 I49.721 J9.077
    G2 X89.844 Y70.129 I-19.235 J-3.843
    X87.479 Y63.918 I-27.642 J6.971
    X84.066 Y58.087 I-50.586 J25.691
    X79.832 Y51.758 I-447.76 J294.998
    G3 X77.489 Y47.824 I35.115 J-23.572
    G1 X77.275 Y47.353
    X77.083 Y46.905
    X77.039 Y46.788
    X78.907 Y46.076
    M5
    G0 Z45
    M5
    G0 X0 Y0
    M30
  6. Gus Mcfarland
    I checked it was enabled changed it same thing
  7. Misterg
    Misterg Veteran
    Make sure that it is set to 'disabled' (and don't forget to save the change). If it was 'enabled' it could cause the torch to switch off at slow speeds (depending on how you're controlling the torch).
    Gus Mcfarland likes this.
  8. David the swarfer
    for plasma, laser mode must be disabled
    then in Fusion360 you need to enable smoothing and set the value to a useful amount, try kerf width as a starting point.
    In short, the torch is slowing in curves because Fusion360 is generating thousands of short Gcode moves, and it takes time to process those thousands of lines of tiny moves.
    Smoothing reduces the line count, the lines don't need to be shorter than the kerf width, so you can fiddle with settings till you get lines of about that length.
    How long is a move?
    Gcode moves from the postion of the previous move, to the position of this move
    G20 ; inches
    G1 X-5.5691 Y0.4451 ; from here
    G1 X-5.5669 Y0.4900 ; to here
    The length of the move is sqrt( (x1-x2)^2 + (y1-y2)^2)
    sqrt ( (-5.5691- -5.5669)^2 + (0.4451-0.49)^2)
    sqrt ( 0.0022^2 + 0.0449^2) signs don't matter since we are squaring so I have left them out
    sqrt ( 0.00000484 + 0.002)
    sqrt(0.00202)
    = 0.04495"
    so, about 1.1mm in this case
    the controller has to do that calculation (and more) for every line it gets, while simultanously driving the motors and checking for errors etc.
    a long sequence of 0.04" moves is usually ok, a long sequence of 0.004 moves will slow it down and that is not ok.
  9. Gus Mcfarland
    Thank you I need time to think about this. Away from Machine
  10. Gus Mcfarland
    thanks a lot. Went back into ink, scape and smooth out my drawing. It works fine now.
