(npn) switch not able to detect limits
Discussion in 'CNC Mills/Routers' started by renatocuts, Oct 29, 2024.
  1. renatocuts
    Hello All,
    First time poster here.
    I am building a RatRig stronghold pro for my workshop and as I move from assembly to electronics I am hitting a few snags (predictable for a woodworker).
    All seems good with the setup and it powers on fine, Blackbox x32is up, switches light up and machine is connecting and jogging fine via Openbuilds Control.
    The problem I am having is that no matter what I do the switches don´t seem to trigger. I also don´t get the unlock alarm that at any time.
    I´ve played with the $5 parametre from 7 to 0 and anything in between and it goes from OFF (on 7) to TRIGGERED (on 0) and a combination of both through the Y, Z , X when the numbers are between 0-5. I cannot action them on the troubleshoot panel in any circunstance and am out of ideas. Any help will be greatly appreciated.
    below is a dump of my config and some images in case it helps illustrate where I am at.
    $$ ] $0=10.0 ;Step pulse time, microseconds
    [11:52:56] [ $$ ] $1=255 ;Step idle delay, milliseconds
    [11:52:56] [ $$ ] $2=0 ;Step pulse invert, mask
    [11:52:56] [ $$ ] $3=4 ;Step direction invert, mask
    [11:52:56] [ $$ ] $4=0 ;Invert step enable pin, boolean
    [11:52:56] [ $$ ] $5=7 ;Invert limit pins, boolean/mask
    [11:52:56] [ $$ ] $6=1 ;Invert probe pin, boolean
    [11:52:56] [ $$ ] $8=0 ;Ganged axes direction invert as bitfield
    [11:52:56] [ $$ ] $9=1 ;PWM Spindle as bitfield where setting bit 0 enables the rest
    [11:52:56] [ $$ ] $10=511 ;Status report options, mask
    [11:52:56] [ $$ ] $11=0.010 ;Junction deviation, millimeters
    [11:52:56] [ $$ ] $12=0.002 ;Arc tolerance, millimeters
    [11:52:56] [ $$ ] $13=0 ;Report in inches, boolean
    [11:52:56] [ $$ ] $14=0 ;Limit pins invert, mask
    [11:52:56] [ $$ ] $15=0 ;Coolant pins invert, mask
    [11:52:56] [ $$ ] $16=0 ;Spindle pins invert, mask
    [11:52:56] [ $$ ] $17=0 ;Control pins pullup disable, mask
    [11:52:56] [ $$ ] $18=0 ;Limit pins pullup disable, mask
    [11:52:56] [ $$ ] $19=0 ;Probe pin pullup disable, boolean
    [11:52:56] [ $$ ] $20=0 ;Soft limits enable, boolean
    [11:52:56] [ $$ ] $21=1 ;Hard limits enable, boolean
    [11:52:56] [ $$ ] $22=1 ;Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
    [11:52:56] [ $$ ] $23=3 ;Homing direction invert, mask
    [11:52:56] [ $$ ] $24=100.0 ;Homing locate feed rate, mm/min
    [11:52:56] [ $$ ] $25=1000.0 ;Homing search seek rate, mm/min
    [11:52:56] [ $$ ] $26=250 ;Homing switch debounce delay, milliseconds
    [11:52:56] [ $$ ] $27=5.000 ;Homing switch pull-off distance, millimeters
    [11:52:56] [ $$ ] $28=0.100 ;G73 retract distance, in mm
    [11:52:56] [ $$ ] $29=5.0 ;Step pulse delay (ms)
    [11:52:56] [ $$ ] $30=1000.000 ;Maximum spindle speed, RPM
    [11:52:56] [ $$ ] $31=0.000 ;Minimum spindle speed, RPM
    [11:52:56] [ $$ ] $32=0 ;Laser-mode enable, boolean
    [11:52:56] [ $$ ] $33=5000.0 ;Spindle PWM frequency
    [11:52:56] [ $$ ] $34=0.0 ;Spindle off Value
    [11:52:56] [ $$ ] $35=0.0 ;Spindle min value
    [11:52:56] [ $$ ] $36=100.0 ;Spindle max value
    [11:52:56] [ $$ ] $37=0 ;Stepper deenergize mask
    [11:52:56] [ $$ ] $39=1 ;Enable printable realtime command characters, boolean
    [11:52:56] [ $$ ] $40=0 ;Apply soft limits for jog commands, boolean
    [11:52:56] [ $$ ] $43=1 ;Homing passes
    [11:52:56] [ $$ ] $44=4 ;Homing cycle 1
    [11:52:56] [ $$ ] $45=3 ;Homing cycle 2
    [11:52:56] [ $$ ] $46=0 ;Homing cycle 3
    [11:52:56] [ $$ ] $62=0 ;Sleep Enable
    [11:52:56] [ $$ ] $63=2 ;Feed Hold Actions
    [11:52:56] [ $$ ] $64=0 ;Force Init Alarm
    [11:52:56] [ $$ ] $65=0 ;Require homing sequence to be executed at startup
    [11:52:56] [ $$ ] $70=7 ;Network Services
    [11:52:56] [ $$ ] $73=1 ;Wifi Mode
    [11:52:56] [ $$ ] $74= ;Wifi network SSID
    [11:52:56] [ $$ ] $75= ;Wifi network PSK
    [11:52:56] [ $$ ] $100=199.100 ;X-axis steps per millimeter
    [11:52:56] [ $$ ] $101=199.100 ;Y-axis steps per millimeter
    [11:52:56] [ $$ ] $102=199.100 ;Z-axis steps per millimeter
    [11:52:56] [ $$ ] $110=2500.000 ;X-axis maximum rate, mm/min
    [11:52:56] [ $$ ] $111=2500.000 ;Y-axis maximum rate, mm/min
    [11:52:56] [ $$ ] $112=2500.000 ;Z-axis maximum rate, mm/min
    [11:52:56] [ $$ ] $120=150.000 ;X-axis acceleration, mm/sec^2
    [11:52:56] [ $$ ] $121=150.000 ;Y-axis acceleration, mm/sec^2
    [11:52:56] [ $$ ] $122=150.000 ;Z-axis acceleration, mm/sec^2
    [11:52:56] [ $$ ] $130=1000.000 ;X-axis maximum travel, millimeters
    [11:52:56] [ $$ ] $131=1000.000 ;Y-axis maximum travel, millimeters
    [11:52:56] [ $$ ] $132=100.000 ;Z-axis maximum travel, millimeters
    [11:52:56] [ $$ ] $300=Grbl ;unknown
    [11:52:56] [ $$ ] $302=192.168.5.1 ;unknown
    [11:52:56] [ $$ ] $303=192.168.5.1 ;unknown
    [11:52:56] [ $$ ] $304=255.255.255.0 ;unknown
    [11:52:56] [ $$ ] $305=23 ;unknown
    [11:52:56] [ $$ ] $306=80 ;unknown
    [11:52:56] [ $$ ] $307=81 ;unknown
    [11:52:56] [ $$ ] $341=0 ;Tool Change Mode
    [11:52:56] [ $$ ] $342=30.0 ;Tool Change probing distance
    [11:52:56] [ $$ ] $343=25.0 ;Tool Change Locate Feed rate
    [11:52:56] [ $$ ] $344=200.0 ;Tool Change Search Seek rate
    [11:52:56] [ $$ ] $345=200.0 ;Tool Change Probe Pull Off rate
    [11:52:56] [ $$ ] $346=1 ;Restore position after M6 as boolean
    [11:52:56] [ $$ ] $370=0 ;Invert I/O Port Inputs (mask)
    [11:52:56] [ $$ ] $384=0 ;Disable G92 Persistence
    [11:52:56] [ $$ ] $396=30 ;WebUI timeout in minutes
    [11:52:56] [ $$ ] $397=0 ;WebUI auto report interval in milliseconds
    [11:52:56] [ $$ ] $398=35 ;Planner buffer blocks
    [11:52:56] [ $$ ] $481=0 ;Autoreport interval in ms
    (sorry, cannot seem to upload images at the mo)
    Thanks in advance!
  3. renatocuts
    Oh yes, it is on 24v. I believe the sensors operate on 10~30v.
    I´ve since swapped the wires as I had them coming into each slot of the x32 ( swapping signal and gnd - the two outside wires) but that did not do the trick. I´ve also managed to trigger the alarm on 2 of the 3 sensors by waving a metal screwdriver in front of them, so there is some communication.
    I still can´t however force the alarm via troubleshooting nor trigger anything when the axis moves close to the sensor (as if they needed more detection range).
    "random" wiring (swopping things just because) is a little reckless and a quick way to destroy a controller (might already have damaged input ports)
    Follow the docs (and label on switches) - they use a black/blue/brown color code where black=sig, brown=V+ and blue=GND -
    Disable hard limits until they are working. Alarms are intrusive, use the provided tools on the Troubleshooting tab to check them
    Only once 100% reliable in Troubleshooting, move on to enabling Hard Limits
    Use something more substantial, needs a decent chunk of metal for inductive sensing
  5. renatocuts
    That was the reason I re-wired them. It seemed they were wired the wrong way around in the first place. I followed ratrig´s scheme (here) and found things weren´t quite matching. Hopefully not damaged anything - anyway I can check?
    If by this you mean using the buttons to manually activate the inputs in the inputs/endstops panels, that is where I get stuck. the buttons for X,Y,Z limits don´t seem to do anything (stuck in green "off" with no effect when clicked) unlike what I see others do on setup videos, where the alarm triggers. Switching $5 to 0 makes them all go into "triggered".
    Maybe I am missing documentation/instructions but what I found here only glances over the limiter setup: https://docs.openbuilds.com/doku.php?id=docs:blackbox-x32:connect-npn-inductive
    Thanks again!
  7. renatocuts
    Hi Peter, just passing to leave a thank you and close off this topic on my side.
    I managed to get them all detected after a bit of tinkering to reposition some and adding metal plates to other parts. all is good and the machine is working fine.
    Thanks for your help and promptness!
