crash need help
Discussion in 'Control Software' started by KEITHABEAR, Dec 3, 2024.
  1. KEITHABEAR
    KEITHABEAR Well-Known
    Firstly why are you flashing firmware? (if its a damaged controller, failing to connect, it also won't come back from a firmware flash).
    Controllers are preflash from the factory
  3. KEITHABEAR
    turned cnc on last night and I don't know what happend but when i tried to home the movement speed was slow and reverse and then i lost the home icon. turned off the back on I noticed that unlock icon was not flashing I pushed the reset button on black box nothing helped
    That's incorrect Grbl Settings. You somehow changed/wiped your Grbl Settings.
    Load your backup you took when it was all working well from Grbl Settings > Restore backup > Select the backup file you saved somewhere safe when everyting was till fine
    If you forget to backup, then you are in for setting it up from scratch like you did the first time (and then remember to backup for next time)
    Firmware update not the solution
  5. KEITHABEAR
    Thanks will do
  6. KEITHABEAR
    I lost backup. How do i get the settings
    CONTROL > Grbl Settings tab.
    If its one of our machines, select machine from list > save and reset when prompted
    If its a custom machine, you've gone through setting it up once before, mainly figuring out your parameters. Use nearest similar machine (or the CUSTOM profile) and modify accordingly Grbl v1.1 Configuration (also on the Grbl Settings tab)
  8. KEITHABEAR
    Its a 1510 openbuilds upgraded to leadscrews and nema 23 high torque motors
    Use the lead 1515 profile and shorten the 1000mm axis you have by 500mm (x or y whichever is shorter)
  10. KEITHABEAR
    reinstall settings and saved, now motors just hit won't move
  11. KEITHABEAR
    Did what you said now its back up and working fine
    Much Thanks
  12. David the swarfer
    now , please do that backup of the settings.
  13. KEITHABEAR
