BlackBox X32
Discussion in 'Other Builds' started by OpenBuilds, Nov 23, 2022.
  1. Peter Van Der Walt
    I cannot understand the error (not in English) but the error should in essence be telling you what the problem is
    Try a different computer, Windows, English preferably (Some of the application does look for English strings)
  2. CIMECH
    CIMECH New
    Hello, I have a problem with the Black Box X32. When I connect them, they work correctly, but after a while, the Black Box short-circuits on the power pin.
    I don't know why this happens. Maybe it's because there's no ground in the connection or the voltage varies for a second and burns the Black Box.
    I need help to find the fault, because it's not the first time.
    I'm attaching images of the Black Box, power supply and connections.
    Thank you very much for your attention.
    imagen_2025-01-07_120921969.png imagen_2025-01-07_120936550.png imagen_2025-01-07_121159702.png
    Nothing obvious from the pictures, but the symptoms you describe has a couple main causes, might give you some clues where to look:
    - PSU wired wire reversed polarity - tends to damage BlackBox on initial connection, but if it ever was wired incorrect, survived, it can still enter similar shorted state later on when the slightly damaged components from that mistake finally fails
    - Other wiring somewhere in the system causing shorts - photos doesn't show other components or wiring for review
    - Mains leakage - any chance you have a VFD spindle or Plasma inverter connected?
    - 3rd party power supplies: Only ever used the Meanwell, or do you have / had any other PSUs connected to it?
    DC GND is connected (GND and +24V are the two wires between the BlackBox and PSU in your pictures, you used Blue to GND)
    AC Earth should always be isolated from DC GND - so double check you don't have any interactions between AC and DC domains - those should always be isolated from one another - PSU in between. Could be a surprising source like a endstop mounted wrong passing DC GND to a frame member, and a VFD spindle with mains earth mounted to that same metal structure causing short between AC Earth and DC GND if a short is present
    James K. Rivera likes this.
  4. CIMECH
    CIMECH New
    I understand the clues you gave me. Now I changed the black box and connected it to the same power supply and the same connections and it works without any problem. That's why it seemed strange to me that the other one gave a short circuit.
    I attached images of the new black box with the same connections.
    The one already damaged will likely continue to stay in that state yes. The question is more of a post-morten - what happened to it, to avoid another suffering the same fate.
    Particularly as it happened again. First one you could maybe brush away as a mistake during first wire up, or somehow even a rare one that just gave up the ghost unexpectedly. Two in a row... Solid indication that something is killing them in use.
  6. James K. Rivera
    I don't know what power cord colors are outside of the US, but solid green is always ground here. You might want to take an ohmmeter and check for continuity to make sure your power cord connections are correct!
    EU/GB/ZA and some others uses Green/yellow as Earth, blue as neutral, brown as live. These countries all have proper 30mA RCD protection at the DB Board too :)
    so his is correct - and on the meanwells incorrect mains wiring unlikely to make an issue on DC side, RCD would trip for an earth swopped with live or neutral, live and neutral swopped will work, though not good practice
  8. Kevin Henning
    Learn something new everyday around here regarding the wire colour allocations :). Hadn't heard of RCD before (known here as GFCI), but being ex-Canadian military RCD means to me "Royal Canadian Dragoons", an armored regiment of the Canadian Forces.
    Same thing essentially, US tends to do GFCI outlets (trips at the wall plug) UK, ZA etc we have a RCD (Residual Current Detector) before all the breakers, so whole building and all plugged in devices are protected. Later regulations puts geysers etc on RCD too, some older regs had fixed fittings like geysers, lights and built in cooking appliances same as US (no RCD, just a overcurrent breaker, relying on a "earth" cable to trip the overcurrent in a fault (full current needed to trip). RCD trips at just 30mA of leakage :)
    Mains switch > RCD > busbar feeding circuit breakers > radial circuits out from there
    Any difference over 30mA between live and neutral = trip
    Pretty nice actually, hard to mess up :)
  10. carpijorge
    Hola ese BlackBox X32 tiene Controlador de altura de la antorcha
  11. Alex Chambers
    English please.
  12. David the swarfer
    Please note that artificial intelligence structures like ChatGPT do an excellent job of translating between languages.
    Por favor, ten en cuenta que las estructuras de inteligencia artificial como ChatGPT hacen un excelente trabajo traduciendo entre idiomas.
    When you arrive at a forum and everything you see is in "one particular language" then it makes sense to post your question in that language, no?
  13. carpijorge
    This Black Box is Torch High Controller THC thank you
    BlackBox does not work with Torch Height Controllers, no. Use a floating head like our OpenBuilds LEAD Plasma uses
  15. CIMECH
    CIMECH New
    Hello, I have a problem with a blackbox x4
    on the axes (X,Y,Z) where the position should be marked. I get disabled.
    #256 Peter Van Der Walt, Jan 21, 2025
  17. CIMECH
    CIMECH New
    Yes, I have an old version,
    I had to enter a new firmware
    and the new versions of openbuilds control do not have the option to update the firmware of a black box x4, it only gives you the option to change the firmware of a black box x32 and the interface
    and thank you very much for helping me with the problem
    have a nice day
