ESTLCAM V9
Discussion in 'Control Software' started by Anthony Bolgar, Nov 2, 2016.
  1. Gary Caruso
    Yes DXF drawing with draftsight is all you need.
    There used to be plugins for sketchup which made DXF files from any sketch but I gave up on sketchup a while ago.
    I have used SVG also, when converting drawings or images off the web, using Inkscape. Estlcam rocks!
    Shhhhh!!, it's the perfect price! ;)
    Gary
  2. Techvette
    Techvette New
    DraftSight works great for flat 2D cuts. If you want 2.5 / 3D, it gets complicated. Sketchup's modeling tools are amazing - it'd just be nice if it would play well with, say, anything else ever.
  3. Giarc
    I have a lot of old files on Sketchup that I wish could be easily converted to DXF. A lot of the simple ones, I just quickly re-drew in Fusion 360. I have yet to try to use a .stl in Estlcam. I may have to give that a shot one of these days.
  4. Gary Caruso
    Ah yes, there is that, good point.
  5. JustinTime
    There is a .rb file that lets you import and export dxf files. Google 'export dxf from Sketchup'.
  6. Arnaldo Nobre
    How can I solve this USB port error problem?
  7. Mark Carew
  8. Arnaldo Nobre
  9. Arnaldo Nobre
    I have already changed the electrical installation, installed a power strip and changed the cutting equipment, but it still has this defect.
  10. David the swarfer
    you can generate Gcode for 2.5D direct from Sketchup using the SketchUcam plugin.
    includes ramping and various hole boring operations for hard and soft materials.
    SketchUcam
