Removing Auto Start
Discussion in 'Control Software' started by Broken Bit, Jan 19, 2025 at 4:35 PM.
  1. Broken Bit
    Sunday
    I installed Openbuilds on a second computer to troubleshoot my hobby CNC machine. My problem was not my computer so I uninstalled the Openbuilds software. But when I start my computer Openbuild startup continues to run at startup. How do I stop the Openbuilds startup routine?
    If irs been successfully uninstalled it will be gone. Try again
  3. Alain JBT
    Alain JBT Well-Known
    I do not know your configuration but if your uninstall does not work try this before:
    If Control starts automatically when Windows starts try to kill the task in the background before uninstalling.
    You find this in your taskbar at the bottom right
  4. Broken Bit
    Sunday
    Thank you, turning off the background task worked (I had to reinstall the software to access the uninstall function).
  5. Alain JBT
    Ok, happy to hear it, it was a possibility.
    Broken Bit likes this.
