Holes That are too Small To cut.
Discussion in 'General Talk' started by fflen, Jan 27, 2025.
  1. fflen
    fflen New
    I am plasma cutting out plates with 6mm holes, what's the best way to mark the hole locations so I can accurately drill them out to size later. I remember reading something about not piercing but just making a mark (they mite of called it pecking) and then drilling by hand later. Does anyone know a good way to mark holes under .250" (to small to cut out with a plasma cutter) and drilled out later with drill press.
    Thanks fflen
    1010 Plasma
    #1 fflen, Jan 27, 2025
  2. Gary Caruso
    It's not hard to do 6mm holes with a 1/8" or 3mm endmill if your program supports spiral cutting, but we've seen people use a center drill bit to mark out hole locations for later drilling.
    Gary
  3. Misterg
    Misterg Veteran
    I've used a 'spotting' drill for this in the past on my spindle machine, but I guessed that the question was about plasma - @fflen Can you confirm either way?
  4. Gary Caruso
    Oh right I suppose I should have known it was for plasma! With the one hint at the end
    Misterg likes this.
