Blackbox X32 and Lowrider 3 CNC
Discussion in 'Controller Boards' started by JW1977, Jan 31, 2025.
  1. JW1977
    JW1977 New
    Hi!
    Can the Blackbox X32 handle a dual motor Z like the one that Lowrider 3 has got?
    Thanks, JW
  3. JW1977
    JW1977 New
    Good news! I would gladly try the Blackbox! When the LR3 homes the Z both motors trigger a microswitch at each side (guess you are familiar with or have heard of the LR?), will this work as intended?
    Specs attached…
    Thanks!
    We may need some help from the grblHAL develops (autosquare, because most of machines has dual Y motors not dual Z) uses the Z input for Y2 (z never homes with Y). But in yours both are Z, so we may need to ask @terjeio's help change the BlackBox plugin so if Autosquare is for Z, it uses Y's input as the 2nd Z switch, so just make sure to log a request https://github.com/grblHAL/ESP32/issues in time before you need it
  5. JW1977
    JW1977 New
    Thing is i need both Y also or am i getting you wrong?
    You can have dual Y (with autosquare) but not also dual Z (with autosquare).
    You can have dual Y (without autosquare) with dual Z (possibly with autosquare but then we'd need grblHAL developer help)
    You can have dual Y with autosquare (already built in) and dual Z without autosquare
    (Autosquare = using two switches for homing to "square" up the axis)
  7. JW1977
    JW1977 New
    Got it, thanks!
