switching between laser and router using interface and using IoT relay
Discussion in 'General Talk' started by AndrewWoods88, Feb 4, 2025.
  1. AndrewWoods88
    How do I switch between the router and laser using the interface on a Lead 1510? I can switch between a Lead 1010 with a laser and a normal router using the control software. Also, how do I wire in an IoT relay to control either the router or air assist using a BlackBox X4?
    bit of info I am using vectric with laser module for design software and tool path creation.
    Either docs:blackbox-4x:iot-and-laser [OpenBuilds Documentation] or simply control which device is powered on (router off for laser jobs and vice versa)
    Use the Coolant port: docs:blackbox-4x:connect-coolant [OpenBuilds Documentation]
  3. AndrewWoods88
    Do you mean laser mode? Either include the $32 commands in your CAM setups GCode Header ($32=0 in router jobs and $32=1 for laser jobs) so its automatic, or change manually on Interface via the usual Tools and Utils > Edit Grbl profile > laser mode option
  5. David the swarfer
    or you can create 2 small gcode files to do it for you and keep them on the interface.
    one has $32=1 for laser mode on and the other has $32=0 for laser mode off.
    Best is to include them in your post processor or cam setup header output so every job has the code it needs.
  6. AndrewWoods88
    Thanks Gentleman I appreciate your help.
